Old 03-13-2022, 10:56 AM   #1
2012 25' FB International
Walnut Creek , California
Bent Axle
After a long road trip last summer we noticed that the front tires were disproportionately worn, on the outside edges. The tires were almost new, got them in 2019 when we bought our 25 ft International. The tire store says its a bent axle. We are in the queue at our local Airstream dealership for confirmation.
Anyone with experience with this? Im interested in what we might be in for in terms of cost.
Kauainot is offline   Reply With Quote
Old 03-13-2022, 12:09 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
The axles actually have a bend in them from the factory to adjust camber. If your tire store is not familiar with that fact they may have misinterpreted what they saw. I'm not saying you don't have a bent axle, but it depends on how bent it is and in what plane.
I would think that an axle bent by hitting a bump, curb or pothole would bend the wheel up and cause wear on the inside edge of the tire.
Did they check the play in your wheel bearings? That could be another cause.
Al
You cannot reason someone out of a position they have not been reasoned into"
Old 03-13-2022, 06:51 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
You can have the alignment of your front wheels on your trailer inspected. Your Airstream dealer can do this, or probably a trailer repair shop can too. Redneck is a Dexter axle distributor and a capable trailer mechanics shop. And since Redneck knows Dexter axles, they can perform an alignment if needed.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 03-14-2022, 10:03 AM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
As stated above the axle tube is made with a bend.
It is a very rare event that an axle tube is damaged so much in service it bends. It is possible just very rare.
The attached pic is of a brand new axle.
Here is the thread about it
https://www.airforums.com/forums/f43...nt-108961.html
Action
Name:	Bent axle 8_26_2013 445 pm.jpg
Axle bent rubbing on undercarriage Modern South Axles 9 03-29-2013 09:38 PM
Bent Axle? memgrove2000 Axles 29 07-14-2009 06:16 PM
Is a bent axle a "dead" axle?? Jason1101 Axles 11 12-12-2007 04:40 AM
axle bent? air66stream Axles 1 10-05-2007 04:12 AM
third axle bent patrick mckenzie Airstream Motorhome Forums 3 06-23-2003 05:32 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
