Originally Posted by gary1burke
I can’t see any bend other than the one that’s supposed to be there in the middle. The wear to the tire took probably 15000 miles to get to where I thought of checking it out so it’s probably not a dramatic bend/bow. Since Weshphil had the same exact issue, I’m wondering if there was a defect. By the way, I checked with a truck alignment shop and they said fixing is not recommended. I think it requires applying heat to the axle which weakens the metal.
...you bend the axles cold...always....they can be straightened....find the correct alignment shop.....one of mine is out of alignment....I just rotate every 8-10000 miles and all is good....you may have had a bad tire...
