Old 04-05-2017, 02:02 PM   #1
1969 31' Sovereign
Pensacola , Florida
Bent axle
I have a 1976, 31 ft Sovereign Land Yacht. I clipped a gas pump pole and bent the front axle. The bad axle will now eat a new tire every 350 miles.
Does anyone know if the axle can be straightened or if I would have to replace it?
LloydHCole is offline   Reply With Quote
Old 04-05-2017, 02:07 PM   #2
2007 27' Safari FB SE
Greenbrae , California
I have had my straightened before but not sure if it made any difference. It's probably better to just replace the axles.
Julie
jaojamjab is offline   Reply With Quote
Old 04-06-2017, 11:00 AM   #3
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
Check the axle for downward angle. Thread with pictures are on the forum.
Good time to replace both (new brakes 12", new bearings, seals, races, shocks and more).
sgschwend is offline   Reply With Quote
Axle bent rubbing on undercarriage Modern South Axles 9 03-29-2013 09:38 PM
Bent Axle? memgrove2000 Axles 29 07-14-2009 06:16 PM
Is a bent axle a "dead" axle?? Jason1101 Axles 11 12-12-2007 04:40 AM
axle bent? air66stream Axles 1 10-05-2007 04:12 AM
third axle bent patrick mckenzie Airstream Motorhome Forums 3 06-23-2003 05:32 AM
