That is a tag from the axle manufacturer Henschen. Henschen torsion axle model was called Dura-Torque.
Henschen started manufacturing torsion axles just after WWII.
Airstream first used Henshen axles in
1961 or
1962.
At some point Henschen was owned by Airstream.
These axles were made in the same town and on the same street as Airstream.
Then Airstream sold Henschen to GKN when Airstream was having economic issues. Then the company was called GKN/Henschen.
Somewhere, early into this century Henschen did not produce enough profit making axles so GKN closed the Henschen axle factory. Airstream did some scrambling and now uses torsion axles from Dexter.
There is not a lot of data from that axle tag. Just the axle weight rating. (Down angle, brake sizing or ???)
The tag is welded on and has some historical significance.
The axle is well past it's prime.
The 27 is likely an internal thing. Like it is the spec for xx model.
On edit - Keeping the tag would be cool. Keeping the axle not so much.
Action
