Old 08-03-2020, 10:54 AM   #1
Cumming , Georgia
Are my axels ok?
I've attached some pictures that will explain the situation. Previous owner had two new axles installed with shocks, but a local guy did it and they look a few inches high. Got a quote from a company that restores airstreams and they said the axles need to be reinstalled to "airstream specs", something about boring another hole to mount them. Its a 1976 argosy. Here are my questions:
1. Can I leave it alone and be safe?
2. If not, what needs done, and can I do it myself?
ID:	374852   Click image for larger version
ID:	374854   Click image for larger version
orangekayak is offline   Reply With Quote
Old 08-03-2020, 11:33 AM   #2
2002 19' Bambi
Lafayette , California
From your photos, I see nothing wrong with how the axles are mounted. It is possible that the drop angle of the new Dexter axles is greater than that of the original Henschen axles. That could be the source of the trailer sitting "too high." I am not aware of any problem that could cause, but others may disagree.
Tim
Tim A. is offline   Reply With Quote
Old 08-03-2020, 11:52 AM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I agree with Tim. I don't see a problem. Sitting a bit higher can be an advantage on off the beaten track roads. What on the install is not to Airstream specs? Cant tell from the photos without a photo of how the axle is bolted to the frame. Is the axle bolted with only 1 bolt on each side of the axle?
Old 08-03-2020, 11:57 AM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Axles no problem....wheels and tires not so much.
I would not put new tires on those wheels.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Mary-Jane....'cuz 2020 sucks"
Tahawus
ROBERT CROSS is online now   Reply With Quote
Old 08-03-2020, 12:39 PM   #5
1976 31' Excella 500
Crewe , Virginia
If you're not happy with those..........
If you're not happy with those axles, I have some period correct vintage axles that I'll trade you for those new ones. I am sure you want it to be as original as it can be......LOL!
I'm actually envious of them and they look good. Enjoy the back roads and bad angled driveways, and intersections.
Dspchef is offline   Reply With Quote
Old 08-03-2020, 12:45 PM   #6
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I'll sing along with the chorus. They look fine to me. It looks like the top of the axle mounting channel is butted against the frame on the other side of what looks like the belly pan. Further it appears the axle beams are going through the cutouts in the frame verticals. I don't see how it can be changed by "boring another hole."
My guess would be that the PO who replaced the axles might have ordered them with more down angle than original,or perhaps even Argosy's all look like that. I think you are fine. Perhaps you could try to get an explanation fo what needs to be changed in the mounting to get a better understanding.
I'll also chime in on replacing the tires (as a minimum) and maybe the wheels as well.
Old 08-03-2020, 12:51 PM   #7
Crewe , Virginia
Hello K5TAN and N4RGO
I didn't realize there were so many HAM's on the portal.
73's
WX4TAG
Old 08-03-2020, 01:20 PM   #8
Hams
73's
WX4TAG
Hey Dspchef,
There are a lot! Even somw threads about it.
https://www.airforums.com/forums/f42...ad-192495.html
https://www.airforums.com/forums/f45...-s-2577-6.html
https://www.airforums.com/forums/f42...am-175141.html
https://www.airforums.com/forums/f45...dio-18441.html
and probably more.
I have a spare Icom 706 I plan to mount in the trailer when it comes back from the repair shop and a spare screwdriver antenna I plan to put in a home-brew motorized lift and lay mount on the roof and I'll probably mount a 2m antenna in the front where Airstream now puts the radio antenna.
73,
Al
Old 08-03-2020, 01:59 PM   #9
2018 25' International
Slidell , Louisiana
I'm with the others, even went out to my 2018 and the gaps and placements look identical to the stock 2018 config. You don't want the axle to touch the pan. The placement on the frame matches also. I think the installer did a fantastic job.
Brian
Old 08-03-2020, 02:33 PM   #10
Cumming , Georgia
Appreciate the wheel concern. Weird question, but whats bad about them? I assume new ones can be picked up at a local tire shop? Anything special to look for?
Old 08-03-2020, 02:42 PM   #11
New ST tires are radials, more wheel stress on a dual axle trailer.
They look exactly like the OEM's on our '63 Safari which were a welded two piece wheel. A quality new steel or alloy wheel makes for good peace of mind.
Molly Ivins
Tahawus
Old 08-03-2020, 04:15 PM   #12
1990 29' Excella
San Antonio , Texas
Noob disclaimer: I have no practical experience, only too many hours researching my axle install.
What does a gutted 24' Argosy weigh, and are 2 x 3500# axles "too much" in its current state? The end result might be a 'riding high' profile. I ask because my 29' 1990 Excella only had 2 x 3200# from the factory. A smaller, lighter(?) Argosy may have started with less, and if your trailer is empty, there's nothing much to compress the axle from its unloaded state.
The data labels on the axle ought to specify the starting angle, and if it's more than 22.5 degrees, that'll contribute to the added ride height. Having read too many axle threads, a common change was to 'upgrade' to 32 degrees.
From the pics, the install seems to be okay and there's nowhere to take out any ride height - the axle bracket is as high as it can go on the frame.
The wheels are also 16" which may add to height from 'factory original.' Again, insert noob/ignorance disclaimer.
joe_in_SAT is offline   Reply With Quote
Old 08-03-2020, 06:04 PM   #13
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
The axles look good!! I would "question" the shop that told you that they need to be in "Airstream spec". Make sure that you replace the wheels with heavy load capacity rims, as that is as important as having the correct axles and tire load capacity.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
1976 22' Argosy
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 08-03-2020, 09:50 PM   #14
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
Not to be too cheeky but the OP asked about Axels. I haven't seen any on the thread yet. Here's a triple: https://images.app.goo.gl/LzgjzpAfmtapb8uX7"]https://images.app.goo.gl/LzgjzpAfmtapb8uX7"]https://images.app.goo.gl/LzgjzpAfmtapb8uX7
Sorry, couldn't resist. - Brad
SuperTrouper is offline   Reply With Quote
Old 08-03-2020, 09:59 PM   #15
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
- Brad
Except the OP has duals not triples!
>>>Action
Old 08-05-2020, 09:07 AM   #16
1988 29' Excella
Lorena , Texas
In the picture it appears that the axles may be resting on the belly pan rather than the frame rail. If the belly pan was trimmed to allow the axle mounting plate to sit directly on the frame rail then you are good. If not you can probably take care of it yourself. The hardest thing (at least for me) was getting the bolts loosened. Yours should not be hard because you’re not fighting rust, but you’ll need a good cheater.
SuperTrouper- I like the axels...
lemley is offline   Reply With Quote
Old 08-05-2020, 11:18 AM   #17
2002 19' Bambi
When I replaced the Henschen axle on our 2002 19' a couple of years ago, the aluminum of the belly pan was between the old axle and the frame. I left that arrangement for the new Dexter axle. I don't think that thin sheet of aluminum between the axle mounting plate and the frame is a problem.
Tim
Old 08-12-2020, 10:19 AM   #18
Highlands Ranch , Colorado
That's the goofiest looking shock angle that I've ever seen. Maybe it's OK for that type of axle but it would be wrong for a leaf spring type axle.
2006 Fleetwood Gearbox 220FB (toy hauler) <- current
2017 F-350 CCLB 6.7L
2019 Nissan Leaf SV+
HRTKD is offline   Reply With Quote
Old 08-12-2020, 11:27 AM   #19
Lumatic's Avatar
1993 34' Excella
Images: 16
Might look goofy but it is correct. The shock is designed for horizontal application.
Old 08-12-2020, 12:43 PM   #20
steinVT's Avatar
1956 22' Safari
1962 28' Ambassador
Williston , Vermont
I just installed to identical axles on my 28' Ambassador. The installation looks fine. Originally I thought I would install a lighter weight also, but Colin Hyde suggested that the 3500# was correct. I also ordered the 32 degree down angle. Maybe you're just used to looking at your old saggy axles.
I agree with CBWELL, I would not trust the shop that said you needed Airstream spec. I think they were just wanting to lighten your wallet. - Mark
Our Restoration Blogs: 1956 Safari and 1962 Ambassador
steinVT is offline   Reply With Quote
Tires for single axels Marathons v Endurance Msherw 2005 and newer - Bambi all models 8 11-07-2017 12:03 PM
Question re: Rust on Axels/Stabalizer Jacks BlubirdFlies Airstream Trailer Forums 10 05-17-2016 09:21 PM
73 Airstream Trailer 2 axels ~ eBay Watch Airstreams on eBay 0 06-06-2011 03:20 PM
Two Brake Axels upallnight Brakes & Brake Controllers 3 05-09-2004 12:11 PM
