07-24-2013, 09:46 PM
1979 23' Safari
, Ohio
'79 low profile axle
My 79 Safari has low profile axles. It seems like most of the axles I've seen on the forums have been the high profile type. I'm really looking for something with the least amount of necessary modifications if you get my drift. I'm attaching a photo of my low profile axle bracket. Any experience with this?
07-24-2013, 09:57 PM
1979 23' Safari
1954 29' Liner
Orange
Thom,
I have the low profile axles on my 1979 Safari also. I have new axles but not installed them as yet. I was told that it is necessary to redrill one hole on each bracket, but not confirmed that. I was also told that there is no redrilling required on the high profile brackets.
I ordered the axles through Colin Hyde by Uwe at Area 63 in Orange, CA.
Hope this helps.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
07-24-2013, 10:14 PM
Corona
Why do you want low profile mounting brackets when most all tow vehicles today are high profile?
The higher profile makes rigging much easier.
07-24-2013, 10:15 PM
Alamo Heights
By "low profile" do you mean worn out such that the arm from the axle to the hub points above the horizontal?
Except for the extra flange wrapped around the back of the bracket, it doesn't look that different from my new ones shown below. Am I missing something?
— David
07-25-2013, 09:12 AM
1979 23' Safari
, Ohio
Hey Bill,
I would be real interested in seeing what your axle brackets look like. So you are saying that they are the high profile?
Thom
07-25-2013, 09:16 AM
1979 23' Safari
, Ohio
Andy,
I'm not sure what I'm gonna end up with at this point, but to answer your question, I had not planned on changing the ride height and profile on my trailer.
Thom
07-25-2013, 09:19 AM
1979 23' Safari
, Ohio
DKB SATX,
The major difference that I see in our brackets is your axle sits about an inch below the body pan and frame. My axles sit flush with the frame and belly pan.
Thom
07-25-2013, 09:30 AM
Alamo Heights
DKB SATX,
Thom
I guess an inch is a big deal where center-of-gravity and hitch height are concerned. I was looking more at the shape of the brackets themselves than the final position of the axle tube, but I see what you mean now.
The change on mine was from old axles to new and it raised the trailer about 1.5" which didn't seem like much, but it gives me more clearance to level in sloped campsites, and gets me a little more drop from the dump valve to the dump station.
— David
07-25-2013, 09:35 AM
1979 23' Safari
, Ohio
Thanks for the info. I may eventually go the same route.
thom
07-25-2013, 09:55 AM
1979 23' Safari
1954 29' Liner
Orange
Thom,
I will post a picture tonight when I return home.
Regarding Andy's post, I went with the low profile bracket and 22.5 degree down angle since I tow with a 1977 Lincoln Continental and do not want a higher trailer. In addition, my wife is in a wheelchair and the lower height of an Airstream makes her entry and exit much easier.
Since I have a vintage trailer, the dump valves do not hang down like the new trailers.
Bill
Hey Bill,
Thom
07-25-2013, 11:57 AM
1979 23' Safari
, Ohio
Bill,
I would love to see a picture of those axles. They are probably close to what I will be getting from Colin as well. Are you putting them on yourself?
Thom
07-25-2013, 07:35 PM
1979 23' Safari
1954 29' Liner
Orange
Thom,
Here is a picture of the existing axle and two pictures of the new axles.
Bill
07-25-2013, 09:01 PM
1979 23' Safari
1954 29' Liner
Orange
Thom,
I will be installing them myself, with help.
Bill
07-25-2013, 09:02 PM
Corona
Originally Posted by wkerfoot
Thom,
Bill
The shock brackets don't have a shock stud in them.
Are you having to install that stud?
07-25-2013, 09:49 PM
1994 30' Excella
alexandria
, Kentucky
Thom,
wished we would have had more time to talk at Carter Caves it was nice to meet you and your family.
Here is picture of my 2nd trailer 89 Excella. I installed Dexter 32.5 degree axles. The double step on the trailer seemed to be the perfect height after this upgrade. The trailer will also be easier to hitch to your pickup.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
07-26-2013, 06:21 AM
1979 23' Safari
, Ohio
Bill,
Thanks for the pics. That looks exactly like mine. Are you using the monroe shocks with those?
Thom
07-26-2013, 06:37 AM
1979 23' Safari
, Ohio
Thanks for the pics Steve,
We had a great time, even though our fridge went out on Wednesday. I was able to fix it when we got home. We were sitting just un-level enough to cause a vapor lock in the coils. I was told by a gentleman who sells refrigerators that turning it upside down would not fix it, so, naturally, that was the first thing I tried. Now it gets colder than my home unit. Time will tell.
Thom
07-26-2013, 07:23 AM
1979 23' Safari
1954 29' Liner
Orange
Thom,
I am using the shocks purchased from Airstream,
Bill
Bill,
Thom
07-27-2013, 08:59 AM
1979 23' Safari
, Ohio
Bill,
Are you going to bolt the shocks on the bracket?
Also, as a side note, I recently weighed my safari having just completed the interior refurb. The total weight (including tongue) was about 4900. I know that I definitely added some weight with my choice of materials, but after adding everything up, its hard to come up with 1000 lbs. I'm thinking they may not have included the AC and propane tanks when calculating the dry weight of 3905.
Thom
07-27-2013, 09:06 AM
1979 23' Safari
1954 29' Liner
Orange
Thom,
The shocks get bolted to the brackets.
They dry weight is just that dry, no water, no propane and no accessories, such as Air Conditioner.
Bill
Bill,
Thom
