Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 01-28-2009, 01:30 PM   #1
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
'56 Safari Bearing Seals Needed
Anyone know of a source for 2 replacement seals? The info on the 2 original seals say: Trostel and #300-156-6F and it is a felt style seal. Thanks!
1956Safari is offline   Reply With Quote
Old 01-28-2009, 01:41 PM   #2
Airstream has not had that seal for many years.
A good replacement is National # 290944.
The O. D. is 3.002, it's 3/8 inches thick and the ID is 1.875 inches.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-28-2009, 01:49 PM   #3
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
Thanks Andy! Where can I purchase those Nationals?
Old 01-28-2009, 02:49 PM   #4
I have no idea.
We have not had them for years, and neither has Airstream.
You might try seal and bearing distributors, in your part of the country.
Sorry, I could not be of more help.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-28-2009, 08:03 PM   #5
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
Does this mean new axles? Jeeeeeezzz Louise, they are only 52 years old.
Old 01-28-2009, 08:23 PM   #6
Silverhobby's Avatar
Greeeneville , Tennessee
Send a message via Yahoo to Silverhobby
Look for a Redneck Trailer Supply house in your area. Look for
www.redneck-trailer.com There are locations across the US.
Kevin with Baity the Lab/Pointer
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Silverhobby is offline   Reply With Quote
Old 01-29-2009, 07:27 AM   #7
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Your 52 year old axles are likely good. The 52 year old leaf springs may need some replacemenr.
There is a Redneck in Albany. However you might want to use the phone and not the road. That white stuff is kinda prevelant.
>>>>>>>>>>>>Action
Action is offline   Reply With Quote
Old 01-29-2009, 07:43 AM   #8
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Napa
Go to a NAPA auto parts they will find the seal for you. National Seals
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 01-29-2009, 11:35 AM   #9
NAPA's cross reference for that seal is # 18808
WBCCI 17109
Old 01-30-2009, 01:32 PM   #10
I also found out that the Trostel seal is on a 1964 Globetrotter I am working on. The NAPA seal is 18808 is only 1/4" in width.
WBCCI 17109
Old 01-31-2009, 08:37 AM   #11
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
Its strange, the NAPA # 18808 seal does not match up.
Old 02-01-2009, 06:25 PM   #12
I WAS WRONG. I have a B-324-16-6 Trostel bearing seal on my 1964 Globetrotter. Cross referenced it is a National Oil Seal # 22550. Best of luck to all looking for seals.
WBCCI 17109
Old 05-22-2009, 01:26 PM   #13
Sacramento , California
I just saw that Trostel on our parts counter.
I measured 1.50 ID x 3.00 OD x .37 high
Try Chicago Rawhide seal # 15241
Metal body with rubber lip seal. Type/Style CRSA1
Have a good day!
francorios is offline   Reply With Quote
Old 05-22-2009, 01:58 PM   #14
Images: 59
francorios,
Welcome to the airforums! Many first posts are a litany of questions, problems, and pleas for help.
Your's is the exact opposite. Kudos.
Old 05-23-2009, 08:29 AM   #15
You're welcome.
I found your forum while searching for info on the Trostel seal.
Just thought I would add my two cents to the thread.
I may have to come back here in the future for that answer.
Have a good day!
axle, bearing seals
1968 Caravel bearing seals coopermr Wheels, Hubs & Bearings 10 08-22-2011 11:14 AM
16' CCD Wheel Bearing & Seals Part Numbers RDM16CCD 2005 and newer - Bambi all models 0 05-21-2009 04:37 PM
'69 GT Bearing Seals dbaur Axles 4 06-10-2006 12:00 PM
Elk needs bearing seals Elk Member Introductions 1 04-26-2006 08:46 AM
Wheel Bearing seals!!! niftypkg Axles 1 07-30-2002 03:35 PM
