Old 04-17-2023, 01:56 PM   #1
3rd RV, First Airstream
ETroup's Avatar
2021 27' International
Orlando , Florida
Send a message via Skype™ to ETroup
Washer Dryer Installed in International 27
Here are some photos of our Washer Dryer Combo installed in a 2021 International 27 FBT in the hallway closet. Needed to modify the closet area to handle the weight, supply hot and cold water, a washer drain standpipe, a new 110 VAC receptacle and an exhaust vent with damper.
I also needed to modify the Equator V3 model 5500 Washer / Dryer Combo to work more efficiently when drying in vented mode. To do this, I separated the internal condenser drying sub-system from the internal air blower intake to enable a much stronger vented air flow.
Name:	20230305_204628721_iOS - Copy.jpg
Modified shelf support carries weight directly to the floor. Installed machine is cargo strapped down via slots in the shelf to tie downs on the floor.
The modified closet space with a drop in tray with tracks to protect the original shelf. Still useable as a closet if you were to remove the machine.
The outside stainless steel Exhaust Vent with Damper Flap.
Name:	20230305_204734184_iOS - Copy.jpg
Vents added to the closet door for adequate ventilation.
ETroup is offline   Reply With Quote
Old 04-17-2023, 02:28 PM   #2
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Nice, clean install!
ETroup, bravo on the professional looking installation!
That’s a very creative use of the wardrobe space. I imagine you are planning to use it with full hookups? How much water does it use for a cycle? Does the dryer use 110V electric for it’s heat source?
Thanks for sharing your work with the Airstream community!
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 04-17-2023, 02:42 PM   #3
Bearstream01's Avatar
2023 25' International
Long Island , New York
OMG LOVE!!! They should SO come that way!!!
2023 Airstream International 25RBT
2019 F250 XLT 6.7L Power Stroke Diesel
14457
Bearstream01 is offline   Reply With Quote
Old 04-17-2023, 02:52 PM   #4
ETroup's Avatar
Orlando , Florida
These machines require 15 Amps on a 110 VAC circuit. Being a front loader, they use about 8-10 gals of water per normal load. They use about 1200-1500 watts when drying.
I bought a tandem circuit breaker to replace the existing single breaker used for the Convection Oven / Microwave and ran an oversized 12-gauge instead of 14-gauge wire to a single receptacle in the closet. Fortunately, there is a cable tray under the floor from the electrical panel to the area under the closet, so this was relatively easy.
Wife wanted to be able to run small loads of mostly white stuff and towels. Being able to run two or three loads as needed greatly reduces the amount of stuff we need to carry. The machine is actually very quiet most of the cycle.
Many of these smaller machines are strangely inefficient drying. I was able to cut drying time in half with my modifications. It was simply a problem of not enough air getting into the machine. There was plenty of heat and fan capacity but not enough airflow.
Old 04-17-2023, 03:30 PM   #5
Dennis C's Avatar
Castle Rock , Colorado
Impressive work!
Dennis
Past:
Airstream International Serenity 23FB
Newmar Ventana 3715
Dennis C is offline   Reply With Quote
Old 04-17-2023, 03:59 PM   #6
rideair's Avatar
Another washer/dryer person!! CONGRATS!!!!!
My 1996 34' Front Kitchen came with a washer/dryer combo from the factory as an option, back in the day.
Enjoy,
Paul Waddell
rideair is offline   Reply With Quote
Old 04-18-2023, 09:49 AM   #7
bolerama's Avatar
2017 30' Flying Cloud
2008 23' International
Keremeos , British Columbia
Images: 30
Wow! That is so impressive! Thanks for sharing. You did a beautiful job.
Lisa and Paul
2017 30' FC | 2002 Chinook Destiny | 2008 23' Int. CCD (written off: hail!)
bolerama is offline   Reply With Quote
Washer/Dryer jjonesnc Washer/Dryer & Dishwashers 49 04-22-2017 04:11 PM
1988 Argosy by Airstream 33 Footer Washer/Dryer eBay Watch Airstreams on eBay 0 06-06-2010 05:50 PM
Washer/Dryer will Not Fill frankandsue Washer/Dryer & Dishwashers 3 11-14-2009 10:53 AM
I need help!!--Univolt, antenna,washer/dryer imeynstein General Repair Forum 27 03-27-2004 11:06 PM
Washer / Dryer mldenis Our Community 1 06-19-2003 02:05 PM
