Originally Posted by qjktx
Uwe,
Your new belly pan looks great!
In post #13 above it looks like you have a white cover/??? where the shower drain trap tries to stick through the belly pan. On my trailer (also a '71 Tradewind) the trap just tries to bulge through the belly pan (kind of ugly). Did that white part come with your trailer or did you add it?
Thanks!
- Mark
Hello Mark,
Thank you for the kind words.
The shower trap cover came with the trailer. I re-used the one from the old belly pan.
You can make one from a PVC drain pipe elbow by cutting the elbow in such a way that you end up with a similar cover. Then paint it, as drain pipe is not always UV stable.
Draw a pattern on it, allowing for mounting ears to be bent out, cut with tin snips or band saw, and rivet it in place.
Good Luck!
