06-07-2023, 05:02 AM
3D printing guy
2023 23' International
Overland Park
, Kansas
Water running down the side of the 23FBT
We have a 2023 23FBT. Right now it's parked in the driveway "sideways" - meaning it's leaning to the right side at 5 degrees - which is the slope of the driveway. Since parking it here I've noticed a small continuous rivulet of water during daylight hours. My hip surgeon says no climbing on ladders for 6 more weeks. At 5:30 this morning at was already 75 degrees. Gets to about 90 everyday with bright sun and high humidity. The A/C is on in the trailer and set at 78 for the CEO.
What's causing this? Do I need to try to fix it? Or is it condensation?
06-07-2023, 05:30 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
The AC is on...condensation runoff, ours vents thru a tube to the ground.
Yours may be plugged or Airstream may have eliminated the drain tube as a 'cost saving' measure
I blow out at every Spring get-ready, electric wire also werks...
Look for it, driver side in front of the axles....
06-07-2023, 10:42 AM
2023 27' Globetrotter
Winder
, Georgia
What Bob said……
I will add that even with your drain tube working , you are still going to get some condensation run off from the A/C in high heat and humidity environments. You will also get just general condensation from the roof. Especially in the mornings.
06-08-2023, 07:19 AM
3D printing guy
Overland Park
, Kansas
Location, location
When we had it backed in so the front was lower than the back nice drips were hitting the LF tire. Since we have wheel covers I made an extension that routed past so that it dripped directly on the ground. No so right now.
My surgeon told me, with my wife present, absolutely no ladders until mid-July. And even then with the hip metal need to be careful for the rest of my life about falls. Oh well.
06-08-2023, 07:52 AM
1971 27' Overlander
2023 28' Flying Cloud
Monmouth
, Oregon
The AC condensation tube is in the street side wheel well on my ‘23 but it is 28ft.
“Let’s be careful out there.”
06-08-2023, 09:25 AM
2012 23' FB International
Woodstock
, Ontario
Our 2012 23ft has the drain coming from inside the refrigerator compartment with a plastic strainer on the end. Your strainer might be plugged
Anyway water running down the trailer is not a crisis and you can address it once you are more able
06-08-2023, 09:44 AM
2019 27' Globetrotter
2023 30' Classic
Denver
, North Carolina
The drain cups for the AC are rather shallow. On my trailer I found that if it was not level side to side the condensation would spill onto the roof and down the side of the trailer like in your picture. Try leveling your trailer and see if it stops.
Dave S
06-08-2023, 10:07 AM
2016 25' Flying Cloud
Selbyville
, Delaware
Most likely your AC drain lime is plugged. Phil Enoch the Airstream door lock guy has a cable that you just run up the line from the wheel well. Just google him to get his info.
Jamie
2016 25' RBT Flying Cloud "Bullseye"
2016 Chevy 2500 High Country Duramax Diesel
WBCCI #9026 Delmarva Unit
06-08-2023, 12:38 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
"The drain cups for the AC are rather shallow. On my trailer I found that if it was not level side to side the condensation would spill onto the roof and down the side of the trailer like in your picture. Try leveling your trailer and see if it stops. "
My guess as well.
You can blow air up the drain tube from outside with a small compressor. You can push 1/8" tubing up the inside of the drain from the ground to see if it is clear.
Unless someone is staying in the trailer you could turn the AC off.
06-08-2023, 01:08 PM
2021 30' Flying Cloud
Airstream - Other
Airstream - Other
Lady Lake
Normal
Our 30 does this even with the drain tubes working. High humidity use will cause it and morning dew run off. I feel for you get better Im facing knee replacement in August getting old is not for Sissies!
06-08-2023, 02:38 PM
PennTexan
2021 20' Basecamp
Centerville
Your A/C condensate drain tube is blocked.. We keep a long wire (a hanger that we straightened out) to clear the tube when Mud Dobber wasps decide they want to nest.
06-08-2023, 03:49 PM
2013 25' Flying Cloud
Wheaton
I could be mistaken, but what you are describing sounds like the drain tube running from the drip tray under the cooling fins in the refrigerator. At least that’s what the tube you describe is for in my trailer.
Greg
06-09-2023, 05:34 AM
3D printing guy
Overland Park
, Kansas
Tube
It's not blocked but it's on the upside. So the water path of least resistance is downhill. Problem solved.
06-09-2023, 06:09 AM
Woodstock
, Ontario
Might have to relook at that
I never had liquid until we ran the AC
Tks
06-09-2023, 10:43 AM
2014 23' International
Hurst
Yep... a common experience. Water down the side is no big deal.
06-09-2023, 10:44 AM
Hurst
Actually, pretty unlikely... its a '23 model.
06-11-2023, 09:12 AM
2020 16' Bambi
Sunset Beach
, North Carolina
It’s not level. That’s all.
06-11-2023, 02:37 PM
2018 30' Classic
Jacksonville
Condensate From Roof
I get the same thing on my Classic. It is not the condensate drains. It is condensate on the roof from AC cooling ducts that are close to the roof next to the AC units.
