Old 05-27-2022, 11:21 AM   #1
curnes's Avatar
2010 23' FB Flying Cloud
McMinnville , Oregon
Water leaking from AC unit
Good Morning from Oregon,
We have a 2010 fb23í Flying Cloud with one AC unit on the roof. This was before they ducted the AC. The problem we have is that occasionally when the heater or AC are running, the unit will spit water on to the floor. My usual solution is to just put a pan on the floor and ignore. But of course my wife keeps pointing out that it is a problem. As usual, she is right.
There must be a drain tube somewhere that is plugged. Iíve removed the cover inside the trailer but do not see any kind of pan or drain to clean out. I also looked under the trailer to see if I could find a drain tube. I canít see one. Any suggestions?
Thanks, Cameron
curnes is offline   Reply With Quote
Old 05-27-2022, 11:57 AM   #2
1997 28' Excella
Daniels , West Virginia
Cameron,
On my 1997 Excella the drain tube is black 1/2 inch located on street side about 30 inches forward of the front tire. Hangs down about 4-6 inches.
When you locate yours you might try a length of nylon trimmer string to clear.
Good luck
rich e is offline   Reply With Quote
Old 05-27-2022, 12:44 PM   #3
2022 27' Flying Cloud
North Las Vegas , NV
About 20 mins in they talk about it:
Brian Mages is offline   Reply With Quote
Old 05-27-2022, 01:20 PM   #4
curnes's Avatar
Thanks Rich, I can’t for the life of me find that drain.
Cameron
Old 05-27-2022, 02:07 PM   #5
2007 27' Safari FB SE
NW Oregon in a nice spot , Oregon
Granted mine is a 2007, but the drain tube is drivers side front of the wheel well. About 2 inches from the outside wall and 4 inches back from the front of the wheel well.
Good luck!!
bweybright is offline   Reply With Quote
Old 05-27-2022, 08:05 PM   #6
curnes's Avatar
Thanks, I’ll have another look for it tomorrow. Would really like to find that sucker.
Old 05-27-2022, 11:43 PM   #7
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Air Conditioner dripping on the floor.
Hi, go to "Air Conditioner dripping on the floor" to see how I stopped mine from dripping.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 05-28-2022, 10:07 AM   #8
2016 30' Classic
2009 25' FB Flying Cloud
Dade City , Florida
AC Unit leaking water
This has happened to us also. Easy fix is to locate the drain by the tire well and connect an air air pump to the drain tube. Run the pump for a minute or so and this usually clears the drain. I use a small electric air pump and it works great.
dbaur is offline   Reply With Quote
Old 05-28-2022, 01:13 PM   #9
2007 25' International CCD FB
Glen Allen , Virginia
AC unit dripping on to the floor
We have 2007 25FB and had similar issues.
When the AC was running we would have water dripping from the AC unit on to the middle of the floor.
I removed inside AC unit plastic shroud and traced the leak to the drain cups on the bottom of the AC unit.
The cups catch the condensation and are connected the drain hose
going the wheel well. The problem was that the cups had cracked and leaked.
Your options are to replace the cups or repair the cracks.
I used JB weld to "glue" the cracks. It worked well and two years later
no leaks so far.
Good luck with the detective work and repair
Bill
Richmond VA
dabhunter is offline   Reply With Quote
Old 05-28-2022, 01:29 PM   #10
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera , Texas
Look for black tube hanging down in the front of the street side wheel well.
banderabob is offline   Reply With Quote
Old 05-28-2022, 01:44 PM   #11
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
There are many threads describing other users' troubles with this same problem. Try searching for "Air conditioner" in combination with "leak," "dripping," "water," "condensate," etc.
If it is a simple issue, it usually amounts to a clogged drain tube that results in an overflow and leak from inside the unit. If you pull the ceiling unit off, you can usually see and inspect the drip "pan" or tubing that is attached to the drip cups that are installed outside, and underneath the AC unit. You can try to clear the tubing from the AC side, or from the drain end (which it sounds like you are having trouble finding).
Causes for dripping that are less trivial can include cracks in the condensate catch pan (if equipped) or leaking tubing (if equipped with drain cups).
One of the less common, but still problematical, causes of a dripping AC unit can be that the butyl goop that seals where the wires come from the interior of the unit to the exterior sags and creates a hole, which allows humid air from outside to be brought into direct contact with the cooled parts of the inside of the AC, thus causing condensate and dripping. Similar thing can happen if your AC is loose, of the foam rubber seals between the AC and the room are damaged. All of this can be inspected from the outside by removing the shroud.
good luck!
Old 05-28-2022, 03:25 PM   #12
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Mine leaked badly after Camping World mounted a new AC but could not get the parts for the drain. I found the tube and followed Bob Cross's advice on how to clear it. The tube was not the problem. The badly broken connection to the old drain pan was the problem. I use a succession of Flex Seal products from Home Depot and they fixed the leak. I used the putty and the tape and the spray on can. I am too old to get on top and pull the AC so I will just ride with this as long as it works Last year was a terrible year to get try to get Airstream service.
Old 05-28-2022, 04:06 PM   #13
curnes's Avatar
I found the drip tube and ran some string cutter line up as far as I could get it to go, then blew some compressed air into the line. I’m hoping this did the trick. I inspected around the AC unit and didn’t see any glaring issues. I guess we’ll find out if this worked on our next trip out. Thanks everyone who responded, lots of good ideas if my “fix” didn’t work.
Propane leaking -- not leaking StreaminGeo LP Gas, Piping, Tanks & Regulators 8 07-26-2016 11:38 AM
A/C --domestic, on for 2 hrs & started leaking from Dometic unit schafman46 Electrical - Systems, Generators, Batteries & Solar 12 05-08-2015 05:42 PM
1969 AC unit leaking inside billy1 Furnaces, Heaters, Fireplaces & Air Conditioning 5 09-25-2011 09:15 AM
Why is my roof leaking around AC unit? Jack West Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 12-20-2009 05:25 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
