Old 03-17-2020, 12:07 PM   #1
coolbabe's Avatar
1976 Argosy 26
Lake wales , Florida
Water draining down the side
I just replaced the original A/C on my 1976 Argosy. The old A/C did not drip down the sides of the trailer. I installed a Mach 3 and it does drip. Why?
Thank you
coolbabe is offline   Reply With Quote
Old 03-17-2020, 03:52 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Do you have a pan drain tube? Did you connect it? It may be clogged. I use safety wire and run it up from the bottom.
Streetside....
Tahawus
Love for the Adirondacks
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
ROBERT CROSS is online now   Reply With Quote
Old 03-17-2020, 04:43 PM   #3
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Thank you
Did you purchase and install the drain cup kit for your Mach 3 air conditioner? If not, there is no way it can drain through the drain tube in the trailer.
Old 03-17-2020, 05:20 PM   #4
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
Our ‘69 Trade Wind did not have factory a/c or internal drain tubes .
So I installed a Coleman Mach 8 in the factory location . But alas the factory wiring is there but hasn’t any slack . So I ran a new line from the front circuit breaker box to the a/c . This was very easy on the ‘69 .
Now to run drain lines that’s another story . I would have to remove the inner skin to do it . That isn’t going to happen.
So the a/c drains down the sides of the trailer . To control where it goes I just level the trailer so it flows off the street side .
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Sun shade pull down for side driver and passenger side. Lford Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 10-22-2018 08:24 PM
Goin' down, down, down... Aironius Axles 12 08-23-2014 08:09 AM
Awnings: are they really up/down/up/down ... Belbein On The Road... 6 06-08-2014 01:55 PM
draining water heater John Greenlee Winterizing, Storage, Carports & Covers 15 12-30-2005 03:04 PM
Electric water heater element: Draining dilema rfield54 Water Heaters, Filters & Pumps 4 05-19-2005 10:07 PM
