Old 07-11-2017, 07:34 AM   #21
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
don't these units need a freon recharge every so often?
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 07-11-2017, 08:15 AM   #22
DKB_SATX's Avatar
Alamo Heights , Texas
If the refrigerant escapes from modern RV AC units and heat pumps, you "recharge" by replacing the entire unit.
David
Zero Gravitas 2017 Flying Cloud 26U | WBCCI# 15566
Old 07-11-2017, 08:34 AM   #23
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Per the suggestion of a fellow traveler I checked the dip switches in a he roof top control box. Sure enough the tech had not selected the correct switches. I now have furnace function but the heat pump pump is only blowing cold air
MICHAEL
Old 08-15-2017, 02:37 PM   #24
AWCHIEF's Avatar
Images: 33
Update. Turns out Dometic sent the wrong AC to my dealership. Not going to point any fingers but it was installed without double checking what was in the box. Skipping the middle of the story and moving straight to the end. I am back home and have a new AC w/heat pump. All is good in the world!
MICHAEL
Old 08-15-2017, 07:09 PM   #25
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Good to hear!
Old 08-15-2017, 07:51 PM   #26
PKI
PKI's Avatar
Walnut Creek , California
Cold AC and hot heat, yes! Good news! Pat
furnace blowing cold air canine camp Furnaces, Heaters, Fireplaces & Air Conditioning 55 07-26-2013 11:14 PM
Hot hot hot aluminum! 58cruzer General Repair Forum 23 06-24-2013 01:08 AM
Heat Pump/Air Condition Blowing Hot Air Safari-Rick Furnaces, Heaters, Fireplaces & Air Conditioning 1 04-24-2012 08:30 PM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
