Originally Posted by RetiredMike
I'm new so be kind.....��
I think my Airstream's furnace heats the holding tanks when it's on. Is that correct? Does anyone know how cold the furnace is capable of keeping the tanks from freezing?
During transport the propane should be turned off? Correct? If so what, if anything, keeps the tanks from freezing?
Thank you for any information.
Welcome.
First...helpful if you share year/model/size. Best way is to update your personal profile so that will appear on your posts under your name. Then we will be better be able to help.
As for your question...propane needs to be on for your furnace to operate. And your refrigerator (set it to "auto".) This leads to a hugely contentious issue in the community...the battle over running with propane on or not. It seems the majority do, to keep their food cold in hot weather. Or, to keep things warm in the winter. The other camp swears it's dangerous and you'll blow up en route. You'll need to choose where you land on that issue.
If your trailer is a more modern model, the furnace will blow warm air into the underbelly to keep the tanks from freezing. I have driven in below zero temps with the heat set to 55---and it's stayed there. The underbelly, probably colder...drafts, less insulation, etc. The other 'gotcha' is...the dump valves freezing, they are exposed. And the exterior shower hose/controls freezing...they are exposed under that little plastic cover.
As a general recommendation, if REALLY cold...like single digits or less...avoid traveling unless the lines have been blown out with compressed air, and tanks emptied...winterized, if you will.
But if you MUST...at least empty your black and grey tanks if you can. Remove the outside shower hose and shower head and store in the trailer, and stuff a small towel into that compartment to insulate the control valve a little better. And make SURE you turn off the water pump OFF...a good practice in any weather (faucets are famous for bumping open during travel, the stories are legend), but especially in cold weather, if something freezes and breaks, you'll start pumping water out through the break.
And stay vigilant. If your towing a 'wet' (non-winterized) trailer in freezing weather, and the heater fails, or you run out of propane--you will likely experience some very unfortunate results.
