Old 09-07-2023, 03:54 PM   #1
2019 27' Globetrotter
Tremonton , Utah
Thermostat reading wrong temperature, fixed!
The HVAC system in my 2019 Globetrotter 27FB has had a problem since it was new. The thermostat read the wrong temperature, as much as 20 F off, sometimes high, sometimes low. I tried replacing the thermostat unit, and the problem continued. It looked like it was reading a remote temperature sensor, but trailers with a single AC unit (like mine) are not supposed to have a remote sensor. It turns out that sometimes the factory accidentally connects a remote sensor, but leaves the sensor somewhere inside the walls or ceiling, creating the bad temperature readings.
The fix was fairly simple. I simply removed the air return screens in the ceiling under the AC unit, found the extra sensor wires, and unplugged the conveniently located connector (photo attached). Immediately the thermostat started reading the correct temperature at the thermostat.
rpgraham is offline   Reply With Quote
Old 09-07-2023, 04:23 PM   #2
2014 27' FB International
Lewisville , Texas
You May Be The First
After reading thousands of posts over many years, this is the first time I have ever heard of this one. Congrats on finding the problem and thank you for posting the results.
NO NOIZE is offline   Reply With Quote
Old 09-07-2023, 05:20 PM   #3
Escape Pod II
John Ware's Avatar
2022 23' Flying Cloud
2018 22' Sport
Orange , Texas
RP, your problem was definitely a head scratcher. Good job!
JEWare
John Ware is offline   Reply With Quote
2016 Classic 30 Rear/Zone 2 Temperature sensor reading low gbnichols General Repair Forum 0 08-19-2022 07:06 AM
Inside Temperature - Zone 1 reading external ArchBuck Furnaces, Heaters, Fireplaces & Air Conditioning 1 08-06-2022 07:14 AM
Refrigerator thermostat readout - wrong wrong wrong BoldAdventure Refrigerators 12 09-18-2015 05:02 PM
Replace "Reading lights" with real reading lights and fans? Belbein Airstream Lifestyle 0 06-08-2014 12:30 PM
Fix that "wrong" battery reading meter!! lebolewis Batteries, Univolts, Converters & Inverters 6 06-24-2006 06:44 AM
