I have a 2014 Airstream with two Dometic airconditioners. Zone 1 works good but zone 2 shows inside temp at 32 degrees. The ac will not cool and the furnace will not shut off. No help from Airstream or Dometic since I am the second owner. All help would be appreciated.
Are you saying the inside temperature of the trailer is actually 32 degrees. If so I would assume the heater would not shut off and clearly the AC would not come on.
More details please
__________________ WBCCI 12156 AIR 3144 WACHUNG TAC NJ6 2004 Excursion 4x4 1991 34 ft. Excella +220,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
common problem if you have a high humidity condition. the line that transmits the inside temp gets wet and send an incorrect temp until it dries out. if you remove the inside cowl you can see the two connectors that look like phone lines. there are threads here about this issue.
Ricky
