I have a 1966 Airstream caravel and I have a Blue Rhino bottle attached with regulator. It doesn't seem like the gas is flowing but it makes a small noise once I turn it on and then whatever gas was in the system then Fades away nothing. So I can't start stove or anything else around gas including the refrigerator,
If anyone has any experience in an original Caravel with gas stove heater water tank and refrigerator any assistance will be great
2010 30' Classic
South of the river
A photo of the regulator and the tank valve connection would be helpful.
Usually when this sort of thing happens it's because the excess flow valve has tripped. You can try closing the tank valve, leaving it closed for a minute or two, then opening it very slowly. That may help.
