RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 12-08-2020, 05:45 PM   #1
1994 34' Excella
Baton Rouge , LA
Seeking advice on our Hydroflame 8535-II furnace - 5A fuse blows
Renovating a 94 Excella that sat up for 10 years. I connected the LP for the first time and set the thermostat to about 75 and turned it on and the fan started blowing after a few moments followed by a click and the sound of the furnace igniting and I had hot air coming out of the ducts. It was a little dusty as it had not been run in a while so I turned it off and vacuumed out the air ducts. The second time I turned it on I never heard the woosh of the pilot igniting and the unit only blew cold air. I had a look, noticed a fuse (5 A) was burned out. Quick trip to the store, replaced the fuse and repeated the steps above, and the fuse burned out again before the pilot lit. I’m thinking it’s something with the circuit board. Has anybody dealt with this issue?
tcarr is offline   Reply With Quote
Old 12-08-2020, 06:27 PM   #2
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Higher than design current draw blowing the fuse?
Blower motor starting to seize?
Bad connections to motor resistance is again drawing high current.
Bad ground wiring.
Debris blocking fan again high current.
Speculations comments not proven by inspection or any testing.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 12-08-2020, 07:14 PM   #3
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
My furnace was doing the same thing. Replaced motor and both the combustion air fan and the heated air fan. Problem solved! Bought all the parts from Amazon. Replaced the sail switch at the same time.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
1976 22' Argosy
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 12-08-2020, 07:50 PM   #4
2018 25' International
Slidell , Louisiana
From the symptoms I would fault the combustion air fan or the sail switch. Before replacing them, I would clean the connections. Since it was working and then you cleaned the ducts, that points to a poor connection on the sail switch. A poor connection reduces voltage causing the current required to drive the fuel solenoid and combustion fan to rise. So clean the sail switch well including the connectors. Clean the other connections while you are at it. If you don't have electro wash, use alcohol.
Old 12-15-2020, 06:57 AM   #5
GCinSC2's Avatar
Tcarr,
Update any luck?
Gary
S/OS #001
Old 01-17-2021, 09:44 AM   #6
1994 34' Excella
Baton Rouge , LA
Update on furnace issue
That’s for all the previous advice. Sail switch was fine and the unit was remarkably clean of dust. After troubleshooting, it was determined that one of the coils was bad. Should be an easy fix...except I can’t get to the coil as it sits right up against the top of the furnace housing. And there is no easy access to this from the back. Further, I can’t figure how to get the unit out because there is a 4th smaller duct coming out of the back bottom of the furnace box preventing t from moving forward and the screw securing it in place faces away and unreachable by screwdriver. I’m pretty fed up at this point.
I’ve watched a few videos where guys remove screws on the outside, disconnect the ducts, and it slides right out. Not mine I can only assume that the furnace was installed early in the process at the factory and cabinets were installed on top of it with no thought to future maintenance.
Sorry for the rant. Has anyone ever replaced a coil and if so, how?
Please pardon any typos. I’m dictating. Thank you in advance
Old 01-17-2021, 01:23 PM   #7
Slidell , Louisiana
I'm not sure what coils you're talking about. Needless to say, I've never replaced one. If you have a saws all and access or a mini all purpose reciprocating tool you may be able to cut the screw...
Old 01-21-2021, 07:03 PM   #8
1994 34' Excella
Baton Rouge , LA
UPDATE: PROBLEM SOLVED.
I removed the external furnace door and from the inside, disconnected the ducts, labeled the wires to the thermostat and power, cut and capped them, and removed the furnace from the inside. I used my grinder with a cutting wheel to access the coils. Disconnected the wires and removed the coils. The one causing the 5A fuse to trip was obviously blown/melted. Slid the new ones on (purchased from Amazon for $36, reconnected the wires, closed the lid and fastened with a few rivets. I then reinstalled the furnace, connected the propane line, turned on the thermostat, heard the fan kick on, the green light on the circuit board switched to red (without the fuse blowing) the valve opened and the pilot lit and - heat began to flow. Im Hopefully this helps someone. PM me for questions. link to a few images: https://imgur.com/zzF7YpO
Old 01-21-2021, 07:20 PM   #9
Slidell , Louisiana
Oh the ignitor coils, of course! I was stumped.... Glad you were able to get the furnace out.
Old 01-22-2021, 06:24 AM   #10
GCinSC2's Avatar
The black coils in your hand, that's what you replaced?
Pretty sure those are the dual gas valve solenoid coils.
And that entire burner assy can be removed w/o removing the entire furnace. You remove some small screws, disconnect couple wires, gas line, exhaust pipe and wiggle it out.
Similar repair here.
EDIT: I have not tried this repair on your model, mine, yes. Several times to clear bugs out.
S/OS #001
Old 01-22-2021, 06:30 AM   #11
Slidell , Louisiana
Thanks for the correction Gary!
Atwood 8535-IV Furnace part replacement Just RVing General Repair Forum 0 11-16-2018 02:10 PM
Hydro-Flame 8535-IV won't light Al and Missy Furnaces, Heaters, Fireplaces & Air Conditioning 0 05-03-2017 10:43 AM
Atwood Furnace 8535 IV, Repair tip. GCinSC2 Furnaces, Heaters, Fireplaces & Air Conditioning 0 01-03-2016 11:38 AM
Atwood 8535 furnace diagnostics...HELP! dznf0g General Repair Forum 4 10-23-2013 10:07 PM
Removal of HydroFlame Furnace on '65 Caravel jlovelady Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-17-2007 10:10 PM
