Secondary thermostat sensor
We are having an issue with the thermostat when using our heat exchanger, and I understand there may be a secondary temperature sensor that is at fault. When no heat is turned on, the thermostat on the wall reads the indoor temperature. However, when the heat exchanger is turned on, the reading is no longer accurate, and has been significantly lower than the interior temp, causing the heat pump to run continuously. We have achieved indoor temps near 80 degrees, yet the thermostat still indicates a temp in the low 50's. I have heard there may be a secondary temp probe in the return air plenum that needs to be disconnected. Can anyone confirm this, and help me to identify the connection? Is it the connection indicated by my finger in the attached photo? We have a 2021 GT 25, FTB with one A/C unit
