Old 02-18-2024, 11:38 AM   #1
2023 25' International
Georgetown , Texas
Sail switch part number search
We have a Dometic DF series furnace on our 2023 25' international - the part sheet from the dealership, tho, says it is an Atwood furnace model afmd30. How do I find the correct sail switch for the unit? We want to carry a replacement and it is not listed in the parts manual from AS
Loyce is offline   Reply With Quote
Old 02-18-2024, 02:15 PM   #2
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Tavares , Florida
This is the one I purchased from Amazon for a spare should I need it. It can be used on an Atwood AFMD30 furnace.
Name:	Screenshot 2024-02-18 at 4.12.12 PM.jpg
2018 27' FBT Globetrotter
2019 RAM Limited 2500 w/6.7 diesel
BRN 22721
Old 02-18-2024, 04:38 PM   #3
JeffKim's Avatar
2023 25' Globetrotter
2021 16' Bambi
Forest Lake , Minnesota
With our 2023 25' Globetrotter has a Dometic DMFD30141 which I would assume is the same heater, I bought these* which are cheaper (not sure if as good) and fit.
*I have an obsession trying to fix our furnace and this didn't fix it. I've tried just about everything else. We have a date in JC in March, so I'll find out what the deal is.
2023 Globetrotter 25FBT "Curly"
2017 Audi Q7 3.0T
WBCCI 6343
JeffKim is offline   Reply With Quote
Old 02-19-2024, 07:12 AM   #4
Georgetown , Texas
Thank you! How did you find the correct part? It seems that I have many numbers that do not cross reference1
Old 02-19-2024, 07:19 AM   #5
Georgetown , Texas
Thank you. Looks like the same device, just without the additional bracket. How did you find the number to fit? Our furnace number doesn't match anything I've found - and the serial number of the furnace doesn't correspond to what is listed.
We had ours at JC last year with a excellent experience
Old 02-19-2024, 08:03 AM   #6
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Loyce, if you look up the switch on Amazon they have a list of models the switch fits (see below screenshots). The second screenshot lists different switches depending on your model.
Here’s a link to the switch on Amazon.
I purchased the same one as Hans627 and swapped our 5 year old Globetrotter’s switch as a preventive measure and will keep the original as a spare since it was working before I replaced it.
Hope that helps you find the correct replacement.
ID:	441201   Click image for larger version
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 02-19-2024, 09:54 AM   #7
1991 34' Limited
Tucson , Arizona
Also buy…
You might also want to have a spare limit switch. Both times my heaters, one in the Airstream and the other in an SOB, went out it was due to a bad limit switch.
It seems that often it’s not the sail switch per se, but spider webs or mud daubers that limit air flow.
Hikingsolo is offline   Reply With Quote
Old 02-22-2024, 02:09 PM   #8
Ancient City , Florida
If one can believe the parts list that came with our 2023 25’ fbq, part #33063
Oops, ours is a DFMD
Oops again, that part number has been replaced by the 33082
G8trwood is offline   Reply With Quote
Old 02-25-2024, 10:28 AM   #9
2019 27' Flying Cloud
Wilmington , NC
Take The Old One In For Comparison
My experience is that the parts list in the furnace Owners Manual is unreliable.
Take the old one or at least a photo and some measurements.
Bob Thomson is offline   Reply With Quote
Dometic cross referenced part number to the AS part number for furnace sail switch. kunzman Furnaces, Heaters, Fireplaces & Air Conditioning 0 10-28-2023 11:02 AM
Atwood Sail Switch Part # ? TravisH Furnaces, Heaters, Fireplaces & Air Conditioning 6 12-09-2022 08:54 AM
Fur In The Sail Switch! Rounder44 Furnaces, Heaters, Fireplaces & Air Conditioning 3 07-04-2020 10:40 AM
Sail switch and dog hair Rak187 Furnaces, Heaters, Fireplaces & Air Conditioning 16 01-30-2020 03:01 PM
Seal Part Number I am repacking wheel bearings and seals have no part number. Ditter Wheels, Hubs & Bearings 9 05-05-2013 02:17 PM
