Old 06-01-2024, 02:16 PM   #1
kevinkatz's Avatar
1965 17' Caravel
Curtis Wright
San Marcos , Texas
Images: 38
Send a message via AIM to kevinkatz
RecPro Houghton Install
RecPro installation manual calls for sealant between the roof and outside gasket. The Dometic did not require sealant. An install video on YouTube specifically for the Houghton says that they choose not to use the sealant and have never had a leak. I am about to put mine on and am debating whether to seal or not. Does anyone have guidance on this issue?
kevinkatz is offline   Reply With Quote
Old 06-01-2024, 03:56 PM   #2
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Hey Kevin, long time! When in doubt, always use sealant! Aluminum is not a very stable metal, it contracts and expands. I installed a Houghton in the rear of one of my trailers and I did use sealant (most like Temppro or vulkem) .
1991 300LE Classic Touring Coach
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 01-26-2025, 06:55 PM   #3
1976 31' Sovereign
Florence , Alabama
Kevin did you end up using a sealant on your AC?
rowejd10 is offline   Reply With Quote
Old 01-27-2025, 08:15 AM   #4
kevinkatz's Avatar
1965 17' Caravel
Curtis Wright
San Marcos , Texas
Images: 38
I did land up using sealant. It was an easy install and I am delighted with the functionality of the unit.
Old 02-22-2025, 02:36 PM   #5
Moreland , Georgia
I used inch wide butyl tape on the underside of the plastic flange, and set it in place and used some strong clamps to squeeze it down in place. after the butyl had squeezed somwhat, the next day or so, i masked around the flange and ran a thick bevel filet seal around the flange using GeoCell sealant. Let it skin over and pulled the tape. It was a week or so before I got the A/C installed (trailer is in a building) and it seems to have worked nicely.
Some of the Houghtons use the traditional foam seal, and I think that is what was on the A/C in the Youtube video and the installation instructions do no differentiate between the flange mount and the foam gasket mount.
Charles
Name:	Houghton Air 03 Mounting ring clamped in place with filet of Geocel applied around the perimeter.jpg
'03 Ram 2500 CTD, 5.9L HO PacBrake six speed std cab long bed Leer top and 2008 BigfootRV 21RB trailer.. Previously, 2008 Thor Freedom Spirit 180, SOLD! 2007 Winnebago View 23H Motorhome, SOLD!
CharlesinGA is offline   Reply With Quote
Houghton / RecPro AC on a T1N Interstate InterBlog Sprinter and B-van Forum 6 05-10-2025 04:18 PM
RecPro ranges AKNate Stoves, Ovens & Microwaves 11 11-29-2023 01:08 PM
Houghton RecPro AC/Heat Pump condensation bdhdig Furnaces, Heaters, Fireplaces & Air Conditioning 10 09-11-2023 06:52 AM
Recpro Houghton air conditioners goswick Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-02-2023 05:04 PM
RecPro Convection Microwave reviews SnooMc Airstream Lifestyle 0 05-06-2020 03:01 PM
