Old 07-22-2020, 08:42 AM   #1
Peterborough , Ontario
Real life Under Bench AC experience?
Hello Airstreamers,
We have a 1973 Argosy (22ft) and are looking for a non Rooftop AC solution. The trailer is currently gutted and benches have been built which are currently empty inside. Anyone successfully installed an under bench Air Conditioner such as Dometic Freshwell 3000 or Truma Sphir?
Can't find much info or examples in North America of people implementing these.
Cheers!
Rollinstudio is offline   Reply With Quote
Old 07-22-2020, 09:06 AM   #2
kidjedi's Avatar
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver , Colorado
Speaking from the experience of having installed a few window units as slide outs (not those specific units you mention), ducting and inline fans are required to make an underbench (or bed) a/c an effective cooling solution.
edit: also, I have seen people install a/c with the "body" inside the trailer, but if you don't get the part of the unit that generates *heat* physically outside of the trailer, then you are effectively just wasting electricity by heating and cooling the same space.
25' 1972 Airstream Trade Wind Land Yacht (heavily customized)
2006 Jeep Liberty CRD (diesel)
BeahmStream.com
kidjedi is offline   Reply With Quote
Old 07-22-2020, 09:10 AM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Someone on the forum installed a mini-split. In current state of rebuild you might look at that option. You can install the “cassettes anywhere and run lines beneath the trailer like the propane lines.
Keep us posted
Peace and Blessings..
Channing
WBCCI# 30676
Anyone have a Dometic Cool Cat Under Bench AC? lisasammy Vintage Kin 2 12-06-2022 10:03 AM
16ft Sport-Valves under the kitchen bench klogan1010 Plumbing - Systems & Fixtures 0 05-28-2016 08:42 AM
Clicking sound under bench - 23' ASchwager Batteries, Univolts, Converters & Inverters 6 05-22-2014 11:38 PM
Under Bench AC with Heat unit truckasaurus Furnaces, Heaters, Fireplaces & Air Conditioning 1 11-24-2011 08:51 PM
First real trip; real dumb mistake... myoung On The Road... 49 03-29-2006 07:37 PM
