Old 10-13-2021, 10:13 AM   #1
2021 33FB Classic
Brady , TX
Smile radiant Heat- 2021 Classic Airstream
Questions:
We are struggling with the radiant heat. It won't go above 60 degrees. We have the propane on and are connected to 110 power while we load up. Any suggestions on the Alde or other tips appreciated!
maryfrances is offline   Reply With Quote
Old 10-13-2021, 10:43 AM   #2
2021 30RB Classic
Tucson , Arizona
Originally Posted by maryfrances View Post
Questions:
Did you set the temp on the Alde screen? Ours was set at 55 deg from the factory.
turonueve is offline   Reply With Quote
Old 10-13-2021, 06:37 PM   #3
2020 33' Classic
DFW , Texas
Hi maryfrances
I recommend a quick call to Truma Technical Support. They are the US distributors for Alde. They can quickly help to troubleshoot.
Cheers,
Mick
no_worries is offline   Reply With Quote
Old 10-13-2021, 07:27 PM   #4
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
If you are running it from the Alde screen, the 110V power is turned on one line, the propane is turned on at another line on the display. In addition, you can set the 110V to high or low power.
The recirculating pump (under the dinette seat has speed settings. If it's set to slow, it will take a while to get going.
The Alde fluid tank is behind a panel in the cabinet above the toilet. It needs to be full up to the line when things are running.
There are multiple air bleed points around the trailer. Each one needs to be opened long enough to eliminate air from the system.
None of this (other that turning things on from the panel) should be required in normal use. The first time the system is fully run, you probably will get air out and need to put some fluid in.
uncle_bob is online now   Reply With Quote
Alde Heating 2018 Classic 30 - Radiant Heat madogkenno 2016 - Current Classic (all lengths) 11 01-09-2018 06:03 AM
Anyone? Installed electric radiant floor heat? pamelake General Interior Topics 24 03-15-2007 09:30 AM
Hot water radiant heat? malconium Furnaces, Heaters, Fireplaces & Air Conditioning 32 07-07-2004 02:27 PM
radiant heat Joan D'Andrea Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-19-2003 10:30 PM
