01-29-2025, 08:58 AM
2023 25' International
Alameda
Quiet down the AC/HP
We don't camp at a pedestal very often - but when we do, we notice that the AC/HP is not the quietest appliance in the universe. It is not making weird or nasty noises, it's just louder than I would prefer. What have you all done to put a bit of muffle on that?
01-29-2025, 09:19 AM
2019 27' Globetrotter
McHenry
I agree, even though Airstream has the ducted vents on newer units the AC \ Heat Pump isn’t quiet.
One trick we’ve learned is to run the unit farthest from where we’re at in the trailer. If we’re spending time in the galley / lounge, we’ll run the bedroom unit (FB model). While sleeping, we’ll run the main 15K unit in the galley. Of course this only works if you have dual AC’s.
Another trick that works while sleeping on our FB model is to open the bathroom door so it blocks the galley. That really quiets things down. This would work on a single AC unit model.
Other than that, it is what it is!
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
02-03-2025, 03:33 PM
2021 30' Flying Cloud
Sioux Falls
, South Dakota
I guess noise is in the ear of the listener. I was about to write that I discounted the statements that the ducted a/c was quite a bit quieter. We had a ducted system on our previous SOB and it was quite loud. Today it got up into the mid-80's and I had both a/c units running. It is quieter than our old Foretravel when it had the original a/c units on it. They weren't ducted, but they were built in 1993 and were very quiet. The newer units that replaced them were quite a bit louder. The ducted a/c units in the previous trailer were just as loud, so I expected this would be loud, too. When the compressor is running the noise is less than when just the fan was running in the Reflection. I'm impressed.
Lest anyone think that maybe the difference is due to age, this trailer is a 2021. That one was a 2022.
David Lininger, kb0zke
7490
2021 Flying Cloud 30 RBQ
02-03-2025, 05:47 PM
2023 28' International
Mercer County
, New Jersey
There are frequently complaints/concerns about the noises from the appliances in an AS. One thing I like to mention is to consider your proximity to the appliances when you sleep. How often do you sleep 6 feet from the AC, refrigerator, furnace, etc.. in your home?
That said, the AC units seem to be pretty loud. I have had neighbors comment on the sound when both are running. There are even occasional reports of neighbors complaining about the loudness
02-03-2025, 06:38 PM
2017 28' International
Jim Falls
, Wisconsin
is!
We do the same. One advantage of having 2 units.
02-04-2025, 10:08 AM
2018 27' Globetrotter
Mooresville
, North Carolina
To Piggy back on Jeff, I’m pretty sure on ours the fan is set to “auto”. You do have the option of turning the fan on a lower setting once it cools down for less noise. When we have one on and the other off (as Jeff suggested) we have tuned the fan to “low” on the one that was “off”. They both share the same ductwork so some of the cool air from the “on” unit makes it the unit that was off. It’s not as loud as both running full blast. This is usually when we only have 30A and can’t run both A/C’s. 30A can handle 1 A/C and the fan.
We do the above with A/C, not the heat pump. I will caution that when you are done with this you have to put both fans on “auto” for the heat pump to work properly. I can’t remember why, I only know I had to do this once and it drove me crazy till I figured it out.
Regarding the heat pump, we don’t use it at night due to the noise. We use a small space heater. Works perfect for us.
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Weight Distribution attached to the Gen-Y Torsion Flex Weight Distribution Hitch
"Roadrunner"
02-09-2025, 08:19 AM
2024 23' International
South of Austin
Thats how they operate. You can't change it.
02-09-2025, 09:04 AM
2023 25' Globetrotter
Ancient City
When walking around campgrounds, I often notice AS have the loudest AC. I wonder if it is low profile units.
02-09-2025, 09:52 AM
2010 30' Classic
Warren
, Manitoba
Stop and think about it, Airstreams are metal inside and out! Sound resonates from metal a whole lot more than wood or fiberglass. bang on a metal pipe, then on a plastic pipe, and you will hear the difference! We live in an aluminum (metal) structure!
ACI #7394
2012 GMC 2500 HD Duramax Denali
2010 Classic Limited 30' ,1994 Excella 34'
1987 Limited 34', 1976 31' Sovereign, 1976 Argosy 22' Gone to new homes
Hensley Hitch
02-12-2025, 10:38 AM
2022 23' Flying Cloud
Watsontown
, Pennsylvania
We've had Airstreams from 1983, 2008, 2019 and 2022. The AC units in the older units were not ducted and they were really loud.
Our 2022 is ducted and is very quiet. We also have the MicroAir EZ Start which quiets the startup of the AC unit.
We also do what others mentioned and put the fan on all the time so it is not starting and stopping.
I think there is something to AS air conditioners being loud on the outside. We tend to camp in state parks where the sites are very big, which helps isolate sites from each other.
I find the furnace to be louder and more disruptive and I hate the vinyl smell from the ducts, but that is getting less and less each season.
But our 2016 unducted AC right in the middle of the small Airstream was really really loud.
02-12-2025, 11:44 AM
2021 23' Flying Cloud
SAINT PETERSBURG
, FL
I have a 2021 23' Flying Cloud and the AC was quiet. Then in 2024 it started getting loud. It was a loose bolt holding the AC on the trailer. The dealer only charged us $80 to fix it!
02-12-2025, 12:03 PM
2023 23' Flying Cloud
Another
, World
I thought it was just me! It actually makes me sneeze. The smell goes away after it runs for about an hour, but still...
We tend to use the heat pump if at all possible instead of the furnace. This year, we have decided to camp into December (typically, our last trip is end of October), so we may be using the furnace more.
Regarding noise, our 2023 Flying Cloud doesn't seem to be any noisier than our 2021 NuCamp Tab400. The furnace in the NuCamp was nearly silent (ALDE system), whereas the forced air furnace is a tad louder, but it's a little more quiet than the AC / heat pump.
02-14-2025, 01:20 PM
2020 28' Flying Cloud
2017 23' Flying Cloud
Hiawassee
, Georgia
Some of the noise comes from airflow through the restrictive vents. Replace a few with the Airkrafters vents and you’ll get better airflow and a little less noise. They’re really spendy but high quality
02-14-2025, 01:41 PM
2022 25' Flying Cloud
NCR
, Ontario
our '23 Fc 25fb had a MicroAir EZ Start built in
its MUCH MORE quiet than our last Sport 22FB
2023 25' FB FC, hatch, Queen,30A,1AC,Awning pkg, Convection uwave.Multiplus 12/3000-50,700A Lion,MPPT 100/30,Orion-TR 30,Cerbo GX,GX touch 50,Lynx distributor,dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors,2 Mopeka LP sensors
NCR,Ontario,VE3HIU since 1978
WBCCI# 21212
02-14-2025, 05:42 PM
2015 23' FB International
2007 19' International CCD
Steamboat Springs
I sleep with PQ wax ear plugs to block out the ambient noise of the AC, highway, trains (think Columbia River gorge), neighbors, etc.
"Keep your eyes on the road
Your hand upon the wheel"
