From inside find the furnace. If it’s under a sink or drawers pull drawers and you might see it. Under sink possibly remove shelf.
The right hand side viewed from inside look for louvers these will be behind the hoses.
If you look online for pics or your furnace manual the round holes are heat out the louvers are cold air return.
