There have been a few discussions on the portable units here on the Forums.
Here is one I found by searching for "air forums portable air conditioner":
https://www.airforums.com/forums/f7/...les-90026.html
But, to quote myself in an earlier thread, the portable units typically have one major design flaw: They only have one exhaust port. This means that air you have already cooled is being pulled into the unit, and passed across the condenser before it gets blown out the exhaust hose that goes through the window/wall. This means that the room you are trying to cool is constantly drawing in warm, humid air through every crack to replace the air that is being pumped out by the portable unit. Some portable units have two hoses, one that pulls air in from outside, and one that recirculates that same air back out after it passes over the condenser. Still, one hose or two, its a big hassle. The portable units generally top out at about 10,000 btu, which isn't going to provide a lot of cooling for your trailer.
They also cost 2+ times as much as a similarly sized window unit. There are also several threads about modifying the installation of a window unit to do the job. The conclusion that I have routinely heard about the under-the-bed window unit installation is that, since cold air sinks, you end up with nice cool feet, but the air up at your head is still hot. This might be dealt with by ducting and fans, but at some point, you are well past the point where it makes any sense.
The mini-split folks are usually pretty happy with the results. Not a trivial installation, though.
good luck!
