Old 05-02-2020, 06:26 PM   #1
Valrico , Florida
Penguin II with cups on Argosy - gasket too thick?
So I've finally gotten around to installing my penguin ii on my 1972 Argosy 22. I'm using the drip cups so I went ahead and installed the second layer of gasket material to the existing one on the unit, but after torquing up the screws it still seems like the unit is too far off of the roof line. Am I doing something wrong? I did add some extra gasket pieces to the sides of the unit to make it more stable and to account for the extreme rounding of be roofline with these older rigs. Could that be causing the issue?
ID:	367048   Click image for larger version
ID:	367050   Click image for larger version
Bigmoe128 is offline   Reply With Quote
Old 05-02-2020, 06:44 PM   #2
dznf0g's Avatar
Oswego , Illinois
Maybe the extra strips are a problem. Lewster always just used 2 gaskets and compressed to the thickness of one.
-Rich-
0.060 aluminum -- too thick for roof overlay? doughpat Ribs, Skins & Rivets 9 11-07-2019 01:08 PM
2005 DuoTherm Penguin Drip Pan/Cups Endl Furnaces, Heaters, Fireplaces & Air Conditioning 10 06-29-2018 07:55 PM
Replacement glass too thick for existing hinge? 63squire Windows & Screens 2 09-29-2017 10:53 PM
Penguin I to Penguin II drain pan? HiJoeSilver General Repair Forum 1 05-25-2015 04:51 AM
Penguin drain pan gasket markdoane Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-14-2006 09:36 AM
