Old 04-06-2021, 07:33 PM   #1
1998 25' Excella
Antlers , Oklahoma
Penguin A/C Replacement
I am having to replace the Dometic Penguin A/C unit on my 1998 Excella...I am installing a new Dometic Penguin II with Heat Pump..I am also replacing my old 4 button thermostat with the Dometic CCC2 thermostat..My question is will I have to replace the old thermostat wire with a new wire and if so what kind...6,8 or 12 wire..
Thanks...
jime4161 is offline   Reply With Quote
Old 07-25-2021, 12:53 PM   #2
1996 34' Excella
Fayetteville , Arkansas
I am looking to do the same thing. Did you find any good information? In fact I am looking at replacing all the roof components and resealing it completely, everyting up there looks pretty worn out.
whypanic is offline   Reply With Quote
Old 07-29-2021, 09:02 PM   #3
2015 25' FB Flying Cloud
Redmond , Washington
You probably already figured this out, but for the next person who comes up with this question- It's a 4 wire that you need for the newer ccc2.
And if a person is looking to replace an ac on a 'Quietstream' ducted trailer please check this thread out. You want to make sure you seal things up in addition to just replacing an ac.
https://www.airforums.com/forums/f42...rs-225734.html
wanderingduo is offline   Reply With Quote
Dometic Penguin Heat Pump Replacement kavosCCD Electrical - Systems, Generators, Batteries & Solar 1 08-09-2017 06:26 PM
Replacement for OEM Penguin heat pump awkirch General Repair Forum 7 09-03-2016 07:44 PM
2006 Dometic Penguin Drain Pan replacement? yogijames General Repair Forum 2 06-27-2016 09:48 AM
Penguin I to Penguin II drain pan? HiJoeSilver General Repair Forum 1 05-25-2015 04:51 AM
Penguin AC replacement Roadtoaster Furnaces, Heaters, Fireplaces & Air Conditioning 3 08-17-2006 06:34 AM
