Old 02-05-2025, 08:05 PM   #1
Petaluma , California
No heat from furnace
I have a 2013 international with a Dometic heater/AC.
When I turned on the heat this morning only cold air is blowing out.
The fan is on auto.
There is propane in the tank and the stove and H20 heater are working fine.
I tried a reset at the thermostat but no change.
Anyone have a clue?
DQ
dquirk29 is offline   Reply With Quote
Old 02-06-2025, 06:19 AM   #2
2022 25' Flying Cloud
Tualatin , Oregon
Start by checking/cleaning dust off the furnace sail switch
Check for a red blinking LED on the circuit board to indicate the error
Reset the furnace rocker power switch
Turn the thermostat to OFF then back to FURN and cross your fingers
Steve
TitusNW is offline   Reply With Quote
Old 02-12-2025, 07:29 AM   #3
JJTX's Avatar
2024 23' International
South of Austin , Texas
The fan is on auto.
Anyone have a clue?
DQ
Pull the cover off the outside panel. See my thread.
JJTX is offline   Reply With Quote
Old 02-12-2025, 03:50 PM   #4
Thanks for the advice. I ended up replacing the sail swith ($12). And everything is working great again. I did not even know what a sail switch was until you enlighten me.
Thanks again
DQ
Any engineers? Furnace exhaust heat. That's a lot of heat! Brandon T. Winter Living 39 12-24-2018 03:11 PM
Heat pump or heat strips? coolwhip40 Furnaces, Heaters, Fireplaces & Air Conditioning 17 05-03-2018 09:27 AM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 04:23 PM
