Old 10-22-2017, 06:37 AM   #1
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
No Furn setting
I recently had The AC unit replaced and went to use the furnace but there was no setting on the control unit. AC and HP work fine. I do have propane. Any suggestions greatly appreciated
urnmor is offline   Reply With Quote
Old 10-22-2017, 06:48 AM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
You will need to change the dip switches to enable the furnace.
Old 10-22-2017, 07:29 AM   #3
2015 30' FB FC Bunk
Ayer , Massachusetts
Get the manual and go through the reset. The thermostat may just need to "find" all of the equipment.
Ted S. is offline   Reply With Quote
Old 10-22-2017, 08:37 AM   #4
urnmor's Avatar
Berlin , Maryland
It just dawn on me that I will need to do a reset as we lost power in the camp ground however I did not bring my manuals so I need advice on how to reset
Old 10-22-2017, 08:44 AM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
When I installed a new AC unit and a new thermostat in my Excella (all Dometic equipment) there was a control box inside the air conditioner that had a series of dip switches. I had to set the dip switches to the correct positions to get the equipment to function.
I suspect those dip switches are not set correctly.
Alan
Old 10-22-2017, 04:40 PM   #6
urnmor's Avatar
Berlin , Maryland
My thanks to all however I have been unable to fix the problem. I reset the thermostat to no avail. I also disconnected the cord to the thermostat and also took the control board off of the front of the CCC but to no avail. So I have two questions first is there a separate fuse other then the one on the fuse panel and if so where do I find it and the second question is how do I get to the dip switch’s?
Old 10-22-2017, 05:30 PM   #7
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
You will need the manual for your specific rooftop unit if you plan to do it yourself. Some dip switches are accessible from the roof, some from the interior.
I did a Google search for Dometic rooftop A/C dip switches, where I found a manual that shows them at the roof portion of the unit. On the unit I installed in my trailer the dip switches are inside a control box mounted behind the air distribution box.
Alan
Old 10-23-2017, 07:00 PM   #8
urnmor's Avatar
Berlin , Maryland
I spoke to colonial AS about the dip switches and was told there were none and that it was most likely the CCC. So I called the Mothership in Jacksonville and spoked to a Service Rep. His response was similar to A W Warn that a dip switch located in the AC roof unit was not set properly. He said the correct setting are shown directly on the inside cover. So now I have to decide if I want to climb the roof and do it my self or drive 200 miles and have Colonial do it
Old 10-24-2017, 10:21 AM   #9
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Do you have a setting that says "Agua"? That is the same as Furn.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 10-24-2017, 10:48 AM   #10
urnmor's Avatar
Berlin , Maryland
I do not have either the Aqua or the furnace setting. I just looked at the shroud on the AC and it looks like I can reach the screws to take it off and look at the settings, however I will wait for by son to hold the ladder. Hopefully I will be able to reach the switches and reset if necessary.
Again my thanks for all of the assistance.
Old 10-31-2017, 07:25 PM   #11
urnmor's Avatar
Berlin , Maryland
Just want to close this out at least for now. It was in fact a dip switch which was not turned on. It was easy to fix. I just climbed a ladder took off the hood on the AC and set the switch.
Again thanks for all of your assistance
Old 11-10-2018, 07:59 PM   #12
Jwf
2018 25' International
Ashburn , VA
Same issue
Had the AC replaced earlier this season. Today went to fire up the furnace and no furnace mode being displayed on the thermostat. I have a FB25 2018 Serenity. If I take the cover off the AC on the roof are the dip switches easy to get to?
Jwf is offline   Reply With Quote
Old 11-10-2018, 08:28 PM   #13
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
There should be instruction, telling you how to set the dip switch positions, in the user/installation manual that came with the AC unit. Once you know where the dip switches are located within the AC unit, you will also find instruction written inside the enclosure near those switches. Be safe, power off!
Alan
Old 11-11-2018, 09:12 AM   #14
Jwf
Ashburn , VA
Thanks. I will.
Alignment setting Jim Foster Axles 5 06-10-2004 01:36 PM
Anyone discover a fuel friendly float setting? IPM Mechanics Corner - Engines, Transmission & More... 18 05-11-2004 11:04 AM
Setting up awning. Help!! Dotti&Ditto Our Community 1 08-27-2003 06:31 PM
Rancho shocks setting qqq Tow Vehicles 3 07-19-2003 11:14 AM
refrigerator setting for maximum cooling qqq Airstream Motorhome Forums 5 07-19-2003 04:21 AM
