Old 04-14-2019, 05:42 PM   #1
2020 23' Globetrotter
2019 23' Flying Cloud
Sugar Land , Texas
Newbie Mistake ...Advice?
Stupid Newbie Mistake! We have had our brand new 2019 FC23FB for 2 months and just took it out for our first camping trip. When coming home and backing it up into the storage facility, I didn't raise the storage door high enough. Husband backed the trailer into the unit and the bottom rail of the storage door hit the air conditioner and cracked the shroud! Has this happened to anyone else? We don't know if the air conditioner is also damaged. I am devastated.
I know we can replace the shroud fairly easily and hope that is all my mistake damaged. Our plan is to order a new shroud and bring the AS home to take off the old shroud and check for visible damage, the plug in AS to the 30 AMP outlet we installed at the house, and see if the AC turns on. Hopefully AC works. If not, we'll take it to the dealer, but we were planning on taking it out again on May 5.
Any advice? Is there anything else we should check?
Seanette and Richard Meserole
2019 FC23FB MesAdventurer
2019 Audi Q8
smeserole is offline   Reply With Quote
Old 04-14-2019, 05:51 PM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Sounds like your experience may be limited, but your logical skills are good. Remove the old shroud and make sure there are no missing pieces in the works before testing. Be ready to turn it off fast.
Its an expense and an inconvenience, all fixable. Many have had much more newbie troubles, and you will both be more aware that enough room is best defined as PLENTY of extra room.
Every oops moves you closer to "expert" status.
Paula
Old 04-14-2019, 06:00 PM   #3
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
You just had your first of many "learnig experiences"!! As long as nobody got hurt it is not too bad of a accident. Check to make sure none of the finns on the A/C are damaged. They are normally at the rear of the unit. Hopefully a new shroud is all that is hurt. Make sure that you only walk on the part of the roof that you can see rivets on. That is where the ribs are, otherwise you will have some dents. Good luck!!
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 04-14-2019, 06:02 PM   #4
Overkill Specialist
GMFL's Avatar
2020 30 Globetrotter
2014 23' International
Dadeville , Alabama
Sorry to hear about your damage. If I were you I would hold off on ordering a new air conditioner shroud until I confirm the AC was working properly. There is no reason to order a shroud only to find out that you have to order an air conditioner that will come with the shroud. Test the AC first and if it works OK order the shroud. If not you can then order a replacement AC unit. Damage is going to depend on how hard it hit the cooling/condensing coil is located in the rear and down the curb side of the AC unit.
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 04-14-2019, 06:18 PM   #5
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Tavares , Florida
I've made some stupid newbie mistakes also. It's a fairly large club.
I would check to see if the A/C works before ordering a new shroud. You mentioned that you had a 30 Amp service installed at home for your AS. Most likely you already know this but make sure it is not 220 volts.
Things happen and then you move on. All the best!
Old 04-14-2019, 06:32 PM   #6
Waterford , New York
That stinks. I made that mistake with my truck. Air conditioner shroud is easy, if you had to make a newbie mistake that one is easily fixable.
I purchased a 23fb right around the same time as you. I love it but it has not left my driveway yet.
Larry1492 is offline   Reply With Quote
Old 04-14-2019, 06:32 PM   #7
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
If you keep this up you’ll soon be experienced like the rest of us. Welcome to the club!
Alumacoot
We are confronted with insurmountable opportunities.
Dan and Liz is offline   Reply With Quote
Old 04-14-2019, 06:38 PM   #8
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
One of my first repairs was replacing the AC shroud. A tree limb jumped out in front of me.
Don't worry! Stuff happens. Look at it as a learning experience.
Alan
Old 04-14-2019, 06:51 PM   #9
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
If the fins are not badly bent, i.e. the tubing bent also, you can get a fin "comb" at an AC supply house and straighten them pretty easily. You can try the AC before you do anything. Pull the cover and look for leaking oil if any tubing is bent. If all is well, get the comb, straighten any bent fins and order your shroud.
Al
You cannot reason someone out of a position they have not been reasoned into"
Old 04-14-2019, 07:22 PM   #10
mkcurtiss's Avatar
1968 26' Overlander
CORDOVA , TN
We have all done similar stuff ! We just are not telling anyone about it ! Don't beat yourself up ! Enjoy that super cool Airstream !
1968 Overlander Land Yacht International
Ford E-350 W V-10 booom!
2018 Chevy Tahoe smooooooth
Find a way to enjoy life and have fun, every day !
mkcurtiss is offline   Reply With Quote
Old 04-14-2019, 07:24 PM   #11
mkcurtiss's Avatar
1968 26' Overlander
CORDOVA , TN
By the way, how does that Audi pull the Airstream? Milage?
Boy I hope I didn't Make a mistake Jay Wheeler Sprinter and B-van Forum 18 02-07-2019 09:24 PM
Classic Newbie mistake on a Classic Boogieshoes 2016 - Current Classic (all lengths) 4 08-04-2016 12:07 PM
Another newbie mistake thread: time to bail out? sandgrubber Repairing/Replacing Floor &/or Frame 2 07-22-2016 10:35 AM
Broken Window FC 25 Mistake & Advice efaehw Windows, Doors, Locks & Vents 2 05-07-2016 01:22 PM
Dumb Newbie Mistake #1 dmcinfo Brakes & Brake Controllers 10 08-12-2010 08:59 AM
