Old 01-01-2020, 11:59 AM   #1
2007 19' Bambi
Glen Mills , Pennsylvania
New Thermostat Missing Furnace Mode
I made a basic error, which I have of course discovered far from home on a cold night. I had the A/C and thermostat replaced on my 2007 Bambi 19 a few months ago. Since we were more concerned with A/C at the time, we failed to test the furnace, and the tech concentrated on A/C as well. Now, on a 25 degree night in New Mexico, we discovered that the Thermostat has no FURN mode !
To compound things, it is the holidays, so running down to the nearest shop is not an option. Here are my questions :
1. Is there a way to manually start the furnace when boondocking, bypassing the controls ?
2. Can I remedy this myself and add the mode ? Is this a dip switch setting or something else accessible?
Fawudd is offline   Reply With Quote
Old 01-01-2020, 12:02 PM   #2
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
take off wall and check the dip switch’s...all you can do...never did this...just plug and played...
Old 01-01-2020, 12:09 PM   #3
Sag Harbor , New York
These "thermostat dip switches" search results may lead somewhere productive IMO:
https://www.google.com/search?q=ther...com&gws_rd=ssl
This topic is above my pay grade, but the threads revealed there look helpful.
http://www.airforums.com/forums/f427...ng-174169.html
http://www.airforums.com/forums/f427...ace-68357.html
http://www.airforums.com/forums/f240...at-160811.html
What brand and model is the stat? Does its manual include a "hard reboot" instruction?
https://www.google.com/search?q=stat...=airforums.com
Good luck!
Peter
Old 01-02-2020, 12:56 PM   #4
2007 19' Bambi
After a bit more research, and removing the air filters, I discovered that I have an RJ11 that goes into an inline coupler, with nothing on the other side. There is a 2nd inline RJ11 coupler which is connected. Could this 2nd RJ11 be for the furnace ? Should there be a splitter there to connect both to the Thermostat?
Second thermostat for Atwood ? What am I missing? doughpat Furnaces, Heaters, Fireplaces & Air Conditioning 14 09-13-2019 11:48 AM
A/C turns on while in Furnace mode dmslawson Our Community 5 06-25-2019 08:55 AM
Missing thermostat for furnace 76 sovereign fast fredy Electrical - Systems, Generators, Batteries & Solar 4 05-18-2016 05:12 PM
Missing title, missing VIN in Texas. kristinatx Title, VIN & Registration 33 02-22-2016 08:54 AM
furnace mode mystery masterfly Electrical - Systems, Generators, Batteries & Solar 1 06-10-2014 04:56 AM
