05-26-2021, 06:09 AM
2019 30' Flying Cloud
Grass Lake
, Michigan
New kind of Furnace Problem
OK, so I've done a search and read about the furnaces that start, then stop again, sail switches and various other issues. Here's a new problem: We're on our first trip of the season and were awakened this morning by the furnace trying to light and not being able to do so. We had not set the furnace to run because it wasn't going to be cold out. I immediately checked the thermostat and it is set, as I thought, to OFF, both zones. Furnace wouldn't stop trying to light, so I pulled th fuse while I figure it out.
Anyone have an idea why the furnace would try to light when thermostat is set to OFF?
I op-tested both AC's as part of my de-winterizing process but forgot to check the furnace.
05-26-2021, 07:11 AM
2020 28' Flying Cloud
2017 23' Flying Cloud
Hiawassee
, Georgia
It seems the furnace is getting a ‘start’ signal. The malfunction is either in your thermostat or in the connection that runs from the AC to the furnace.
You will need to trace that signal back to see where the problem lies. There are some switches at the AC unit that need to be properly configured, but I’ve not heard of this causing false starts.
05-26-2021, 07:18 AM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Was the thermostat set to heat pump? If it was the furnace is in “standby” mode. If the heat pump fails to satisfy the thermostat in a designated amount of time the furnace will step in. If you propane was empty or off the problem you experienced could occur and nothing be wrong.
05-26-2021, 07:38 AM
Grass Lake
, Michigan
Thanks!
T-stat is set to OFF, not heat pump. Yes, already checked gas and we have propane, WH and stove both work.
05-26-2021, 07:41 AM
Grass Lake
, Michigan
Thanks! I was hoping for something simple. If it's that involved, I'll have AS look at it. Although I have the ability to trace signals, I just don't have the inclination or time to do extensive troubleshooting for something that is still under warranty.
05-26-2021, 11:22 AM
Airstream Ambassador
Jackson Center
, Ohio
Hi oldenavy,*
Please send us a direct message with your contact information, email and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customersupport@airstream.com
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
05-26-2021, 12:40 PM
1988 32' Excella
Robbinsville
, New Jersey
There is a way to reboot the thermostat. Probably worth a try.
