10-22-2021, 01:54 PM
1986 31' Sovereign
Miami
New A/C seems to produce less condensate
So, just headed home from Jackson Center where I had a second a/c installed to help me deal with summer camping in Florida.
The new unit, a base model 13.5k btu Penguin II (no reverse cycle, no heat strip) drains about 1/5th the amount of condensate that the original Penguin heat pump 15k unit produces.
I don’t see water draining anywhere else.
Am I overthinking it?
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
10-22-2021, 01:58 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
What's the temperature out *and* what's the humidity? Put another way: what's the dew point? The numbers in August are going to be *very* different than what you see in October.
10-22-2021, 02:13 PM
1986 31' Sovereign
Miami
80f and about 55% humidity. I have both a/c’s running. Pretty steady condensate stream from original 2008 Penguin. New unit drains a small amount every now and then.
I will say that the old unit has the solid cover and the new one has ventilation holes in three sides. I’m wondering if dometic did something to enhance evaporation in the modern units?
Young, lovely bride
Dismissive cat
10-22-2021, 03:39 PM
2004 30' Classic Slideout
Fenton
, Missouri
The other thought that the larger unit most likely presented more coils for the air to flow through. As you step up in size on most air conditioners, the units have to contend with more square footage. Therefore fan speeds tend to be slightly different and the interior coil size has to compensate for that larger square footage to be cooled and the resultant air flow throw those coils. The coils may be the same physical dimensions on width and height, but I bet there is also some difference in the depth of the coils.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
10-22-2021, 03:49 PM
2008 30' Classic
Collierville
, Tennessee
Were you wired for 50amp before
10-22-2021, 06:16 PM
1986 31' Sovereign
Miami
Didn’t rewire for 50A. The second a/c has it’s own 30A plug and circuit breakers.
It works great. When I get home I’ll drop the distribution box and see what’s what…
Young, lovely bride
Dismissive cat
10-23-2021, 11:49 AM
1988 32' Excella
Robbinsville
, New Jersey
The original A/C coils might be a little colder causing it to do most of the dehumidifying. Possibly same fan speed with more cooling on larger A/C. Might need to run 1 A/C at a time (in identical conditions) to find out what the real difference would be.
10-23-2021, 05:31 PM
1986 31' Sovereign
Miami
Excellent suggestion. I’ll give that a try. Thanks.
Young, lovely bride
Dismissive cat
10-23-2021, 05:48 PM
1988 34' Limited
Mobile
, Georgia
Wazbro has the right of it. The amount of condensate is a direct function of the RH, temp, dew point of the indoor environment. The air passing over the evaporator coil (that produces condensate) should only come from inside your trailer. You could also park it, open all the windows & doors and run them both and see what happens. Source: am HVAC tech.
