Old 05-18-2022, 06:37 AM   #1
2014 30' Flying Cloud
Delaware , Ohio
Neoprene plug on water heater
We have a 2014 Flying Cloud. In the last week our water heater has developed pin hole leaks in the plug on two occasions. Each time the plug was replaced with a new plug. Any ideas what is causing this?
ret155 is offline   Reply With Quote
Old 05-18-2022, 08:33 PM   #2
2017 25' International
West Lake Hills , Texas
Tighten the plug all the way to the shoulder. Takes a wrench. Buy a spare plug. Use the Atwood plugs. The Camco plugs are not quite as good a fit.
Fungus is offline   Reply With Quote
Old 05-18-2022, 08:58 PM   #3
dznf0g's Avatar
Oswego , Illinois
I have always wrapped the threads with teflon tape. Never had a leak.
Sent from my SM-G950U using Airstream Forums mobile app
-Rich-
Old 05-18-2022, 09:08 PM   #4
Escape Pod II
John Ware's Avatar
2018 22' Sport
2022 23' Flying Cloud
Orange , TEXAS
Use a brass plug that uses a hex allen socket. I don't know how to attach a thread but ck out the one started by OARfan on 3/15/2016.
JEWare
John Ware is offline   Reply With Quote
Old 05-19-2022, 09:46 AM   #5
Portage to Caravan's Avatar
2014 23' FB Flying Cloud
Petrolia , Ontario
Brass instead of poly
I'd considered using a brass plug instead of the original poly plug, as it would last through many re-uses, but I believe they used a plastic plug as a safety precaution. If your water heater has a temp. runaway the poly will melt allowing the water to escape rather than rupturing your heater tank. That would be a real mess. Your best bet is to wrap the plug with teflon tape before inserting and change it out with a new one every couple years. They do wear out with frequent uses are readily available and are reasonably cheap.
Portage to Caravan is offline   Reply With Quote
Old 05-19-2022, 09:49 AM   #6
2014 27' FB International
Hooper , Utah
Do not use the brass plug.....brass reacts to the metal in the tank and will result in issues. Brass sound nice and is a strong metal, but you cannot connect two different metals.
albret is offline   Reply With Quote
Old 05-19-2022, 09:55 AM   #7
Petrolia , Ontario
An even better point. Dis-similar metals will cause corrosion that will prevent you from removing the plug in the future. Known as galvanic reaction.
Old 05-19-2022, 10:22 AM   #8
ITSNO60's Avatar
Tucson , AZ
I don't think that is true, after all the TPR valve is brass. I find conflicting info online but I did remove my TPR after 11 years and saw no evidence of any corrosion, nor was it hard to unscrew.
After some research this seems to be a longtime hot subject on a number of discussions but I fail to see a problem in light of the brass TPR valves not causing issues on the same water heaters.
Brian
ITSNO60 is offline   Reply With Quote
Old 05-19-2022, 10:25 AM   #9
ITSNO60's Avatar
Tucson , AZ
The TPR valve would open long before hot water would melt a nylon plug, the reason they used the nylon plug is 1. It was cheaper and 2. Less chance of an unskilled DIY owner stripping the threads on the aluminum during annual winterizing. (IMHO of course)
Brian
Old 05-19-2022, 10:49 AM   #10
ITSNO60's Avatar
Tucson , AZ
Brass and plastic aside I do know that the genuine Attwood plugs are NYLON and are superior to plastic or PCV which is a good reason to spend the extra money if you want to go with a non-metallic solution.
Brian
Old 05-19-2022, 11:39 AM   #11
1996 25' Excella
Tillsonburg , Ontario
Plastic plugs should be nylon
PVC melts at 185 F so would creep and deform at 140F temp in the WH
HDPE at 135 F a definite no go!
Agree that “plastic” is less likely to damage the tank fitting
I always had trouble getting the replacement plug from an RV warehouse to start since the pipe thread on the plastic plug was a poor match to the tank.
JCW
JCWDCW is offline   Reply With Quote
Old 05-19-2022, 11:55 AM   #12
Streamracer's Avatar
1986 25' Sovereign
Huntsville , Alabama
I installed a petcock so when I want to drain the tank just open it up. Never a problem in several years
Streamracer is online now   Reply With Quote
Old 05-20-2022, 08:05 AM   #13
Petrolia , Ontario
Brass plug here we come
Well that "seals" it. I'm going to find a nice brass plug to install the next time I change out the drain on my water heater. All this input makes it clear now with thread damage being the most likely reason for a plastic (nylon) plug.
Thanks everyone for chiming in.
Old 05-21-2022, 01:30 PM   #14
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Overtightening the nylon plug could have caused it to distort just enough to leak. Just past firm should do the trick. Has done well for me.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 05-21-2022, 02:06 PM   #15
Mollysdad's Avatar
Okay.
Okay.
Old 05-24-2022, 08:03 AM   #16
Ready-to-Travel
pmclemore's Avatar
Dad, I get your point. Here's my theory: Since pipe threads are tapered, plug gets bigger the tighter you go. As the plug is nylon - softer than the fitting - it may be possible to distort the plug if it is tightened too far.
Pat
AIR 3987
TAC VA-2
WBCCI 4596
Old 05-24-2022, 11:10 AM   #17
Escape Pod II
John Ware's Avatar
2018 22' Sport
Orange , TEXAS
I've found that when screwing plastic pipe fittings into metal fittings to use lots of Teflon tape.
JEWare
Old 05-24-2022, 12:46 PM   #18
2012 28' International
Prince Edward County , Ontario
+1 regarding the Atwood plug. I use a socket with an extension to just snug up the connection.
Cyclist is offline   Reply With Quote
Old 05-24-2022, 02:23 PM   #19
SilverWind's Avatar
1968 17' Caravel
Los Osos , California
Does anyone happen to know the size and model number of the plug for the GE9EXT Atwood/Dometic water heater in my 2017 International 25?
SilverWind is offline   Reply With Quote
Water heater drain plug dripping even with a new plug wmb Water Heaters, Filters & Pumps 23 11-04-2021 06:18 PM
Neoprene washer with cap jasfox Plumbing - Systems & Fixtures 0 07-12-2015 09:59 AM
Neoprene tubing L911 Fresh Water Systems 4 06-27-2012 11:01 PM
Trailer plug - Adapter or New Plug?? Jason1101 Brakes & Brake Controllers 4 01-23-2003 05:24 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
