Old 01-23-2022, 02:13 PM   #1
2018 33' Classic
Thousand Oaks , CA
Need some help
I have a 2018 33 classic that a dealer replaced two AC's. Said it was leaking freon. Now they can't get them to work with firefly system. I need to know the following
- The dealer says only one AC in the classic is able to use the heat pump. This does not make any sense.
- Since I have the 1.7 GUI of the firefly they are saying this system needs to be update to the lasted firefly system. Does anyone have any experience regarding this issue?
candrews768 is offline   Reply With Quote
Old 01-23-2022, 04:22 PM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Most recent update is 3.8 on our 2018.
Both our heat pumps work when we are on 50a shore power.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 01-24-2022, 08:03 AM   #3
2018 33' Classic
Thousand Oaks , CA
Did it come with 3.8 or did you upgrade it to that.
Old 01-24-2022, 12:02 PM   #4
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
If they put in the correct units, then both A/C's should run as heat pumps. If they replaced one of the originals with an "A/C only" model then you lost the heat pump function.
Upgrading the firmware should be a fairly trivial process. No different than doing an update on your phone. One would guess that if you are on 1.x and the rest of the world has moved to 3.x (or past that), you most certainly need an update. It is possible that multiple parts of the system need updates. Still trivial, but time consuming.
Old 02-06-2022, 11:08 PM   #5
2018 33' Classic
Thousand Oaks , CA
So the new units, penguin II will not work with the 1.7 gui of firefly. 5K to update the software. Ridiculous I agree. So I am asking Jackson to cover it. Good luck with that, we will see.
If that does not work will have someone other than AS install a separate thermostat. Personally I am done with any AS dealers, they are lame
Some of my 12volt is working but some not. b1gflip Electrical - Systems, Generators, Batteries & Solar 4 03-13-2018 07:35 AM
Some GFI protected circuits work and some don't. Two Peas On The Road... 21 02-02-2016 04:27 AM
Some progress and Some Questions SCopp 1970 - 1973 Overlander 3 02-03-2013 07:25 AM
Some call it a hobby, some, an addiction balrgn 1974 - 1977 Overlander 45 08-18-2008 07:32 PM
Need some help Rubyslipper Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 04-29-2003 01:53 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
