Old 12-07-2024, 04:24 PM   #1
funkill's Avatar
Tucson , AZ
Images: 27
Need old Honeywell A/C thermostat
Greetings. I removed my old Honeywell thermostat earlier this year to access some cabinetry, and now I can't find it. I've searched high and low, and after spending about three hours on the web, I accept that they are no longer available. I can't find anything that even looks close to it.
Well, I did find a similar, but different model # "sub-base" but it doesn't have the cover.
It is for a 1973 Armstrong air conditioner, that was working perfectly.
I took photos of the thermostat when I removed it so I could hook it back up easily. It has three adjustments: fan high/low, cool or off, and temperature range.
Does anyone have an old thermostat they'd be willing to sell to me? Or could recommend a replacement?
Thanks in advance,
Funkee
ID:	449335   Click image for larger version
FunKee - and the Silver Olive
2006 F-150 Lariat QuadCrew
AIR 31804
WBCCI 10718
funkill is offline   Reply With Quote
Old 12-07-2024, 04:39 PM   #2
2022 25' Flying Cloud
Tualatin , Oregon
I would think this White Rogers from Amazon would fit your purpose:
https://a.co/d/4vvRxzD
Steve
TitusNW is offline   Reply With Quote
Old 12-07-2024, 04:44 PM   #3
Tualatin , Oregon
Sorry, that one is heat only...
Old 12-07-2024, 05:40 PM   #4
funkill's Avatar
Tucson , AZ
Images: 27
Thanks for trying....
I've spent like 4 hours searching the internet for something that will work. I think maybe a thermostat with option for heat could be used, just not utilizing that option.
My problem seems to be that I don't have a negative. One replacement thermostat mentions "if there is no negative 12 VDC supply at the thermostat, a negative wire from the power supply to the thermostat must be added". Not sure how to do this.
Green/G1 - I think this is fan low
Red/R - I think this is 12v
Black/G2 - I think this is fan high
Br/Y - I think this is cooling
AIR 31804
WBCCI 10718
Old 12-07-2024, 05:43 PM   #5
Tualatin , Oregon
Search for 'replace old thermostat' and see if the videos make sense for a swap/upgrade
Steve
Old 12-08-2024, 11:20 AM   #6
2020 23' Flying Cloud
San Antonio , Texas
Thermostat
Thanks in advance,
Funkee
You can use a T 87 thermostat with a q heat off cool sub-base. It is round but there is a conversion cover plate available.
Honeywell Home CT87N1001 The Round Non-Programmable Manual Thermostat, Large, White - Programmable Household Thermostats - Amazon.com
Old Fart is offline   Reply With Quote
Old 12-08-2024, 05:51 PM   #7
rideair's Avatar
Mr. Fun,
I’ve got a 73/74 Argosy that might have one hanging on the wall, will check tomorrow and let you know.
Enjoy,
Paul Waddell
rideair is offline   Reply With Quote
Old 12-09-2024, 08:27 AM   #8
lemley's Avatar
1988 29' Excella
Lorena , Texas
Any old school analog AC/Heat thermostat should work. Here’s one from Grainger:
https://www.grainger.com/product/2E1...B&gclsrc=aw.ds
Honeywell Mfr # CT87N1001/E1 (available at Ace) will work.
You could also “upgrade” to digital, but you would need to replace the batteries, probably about once a year.
I went a bit overboard on mine. I added a 24 volt AC inverter and used a Honeywell WiFi, same as the one I use in my house. It is really convenient to be able to control the thermostat from my phone. The wiring for the WiFi thermostat is a bit tricky since it’s designed for use with a 24 volt conventional home system. I can post that if anyone is interested.
lemley is offline   Reply With Quote
Old 12-15-2024, 12:14 PM   #9
1972 23' Safari
Fairburn , Georgia
I have a similar looking one from a 72 Safari.
Losttbison is offline   Reply With Quote
Adding a Honeywell thermostat to a Dometic Brisk II AC lemley Furnaces, Heaters, Fireplaces & Air Conditioning 0 05-27-2024 05:28 PM
Adjusting '69 Honeywell Thermostat fotochop Furnaces, Heaters, Fireplaces & Air Conditioning 8 02-27-2010 09:58 AM
Honeywell Inverter Generator moosetags Generators & Solar Power 4 11-17-2009 07:40 PM
Honeywell 2000i generator Cochese Generators & Solar Power 4 08-10-2009 11:48 PM
