Old 11-28-2018, 09:57 PM   #21
1990 29' Excella
baltimore , Maryland
Oh, due to the airstream body tapering in as it goes down, I had to shim up the back (part of furnace most inside the rv) of the furnace to bring in the bottom front edge to match the outside skin.
groundhogy is offline   Reply With Quote
Old 11-29-2018, 07:54 AM   #22
1976 31' Excella 500
Chappell Hill , Texas
[Should I spray construction foam between the inner and outer skins? Would this seal and prevent water from falling in there?[/QUOTE]
Nope. Foam is not water proof protection. It's a gap filler and insulator maybe but still needs to be sealed over. I do wish Airstreams were insulated with foam like the old Avions were.
tbashin is offline   Reply With Quote
Best way to cut a 3" hole in the airstream skin? gomotomoto General Repair Forum 28 05-27-2020 07:51 AM
I shouldn't have cut the porch light wires... Midamrail Lights - Interior & Exterior 5 07-27-2018 01:40 PM
Tow hitch cut need help figuring this out Airstreamla Repairing/Replacing Floor &/or Frame 10 05-02-2018 11:41 AM
May have found new product to cut through corrosion! Air Cruiser Cleaning, Stripping & Polishing 4 07-31-2013 10:15 AM
rectangle with round ends or slipstream whatsherface Repairing/Replacing Floor &/or Frame 1 06-26-2010 06:05 PM
