Old 09-09-2019, 12:14 PM   #21
1981 31' Excella II
New Market , Alabama
I have problems with Dometic thermostats. Once you get down in the 70's as far as air temp the unit start cycling on and off and it really limits cooling because it is only running 25-50% of the time. It got so bad this weekend that I had to heat up the thermostat with a hair dryer. In the Airstream, I took a Coleman thermostat and installed it and no more short cycling problems when the temp gets below 80 degrees. Much of the problem is caused by air leaks that leak cold air onto the thermostat sensor. I have had this problem with two different Dometic units and one has the thermostat in the AC housing and the other has it close to the unit on the wall. It is like a purposeful design flaw.
Perry
Old 09-10-2019, 06:54 AM   #22
yes , Georgia
Originally Posted by perryg114 View Post
I have problems with Dometic thermostats. ….I have had this problem with two different Dometic units and one has the thermostat in the AC housing and the other has it close to the unit on the wall. It is like a purposeful design flaw.
Perry
Sounds like just the temp sensor needs to be relocated. I have never done this but it can't be that difficult. Can you just make it longer and put the temp sensor outside the unit, not inside?
I have similar issues with Fantastic-fan with its sensor inside the air flow. When on high speed it cools off so fast that it cycles too much. If the sensor were in the room and not in the air flow then I would get more consistent cooling (its just air, not chilled air). Like the AC it is the little copper thing
silverhio is offline   Reply With Quote
Old 09-10-2019, 08:26 AM   #23
1981 31' Excella II
On the unit that is in the AC you can't move it very far away. It has a sense tube attached to the thermostat.
Perry
Old 10-08-2019, 09:05 PM   #24
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
Originally Posted by kayakcook View Post
A good Sam agreement should cover the repair
Good Sam purchased post problems? Will they honor that? I have not had luck with them before and dropped them.
FC7039 is offline   Reply With Quote
Old 01-06-2020, 06:57 PM   #25
FC7039's Avatar
Allen , Texas
How about this for a deal? Next day it is up to $400 but still a deal. I can buy a white shroud and still pay less than what I was planning. But I think I will spray paint silver first to see if I like the look.
Old 01-11-2020, 03:47 PM   #26
FC7039's Avatar
Allen , Texas
Old (white) New (black, to be painter silver)
The new is only 3” taller. Same width. Much shorter and lighter.
Old 01-11-2020, 05:24 PM   #27
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Looks great. I love the idea of painting silver.
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 01-16-2020, 06:17 AM   #28
Carrollton , Kentucky
Drip pan
Are you able to use the drip pan with the Mach 3? I've been wanting to replace my temperamental AC but was under the impression I would have to drain off the roof if I did.
MichaelS is offline   Reply With Quote
Old 01-16-2020, 08:00 PM   #29
FC7039's Avatar
Allen , Texas
I have drip cups. It requires a second level of a seal. They only worked so-so on the Penguin but I will use them again.
Old 01-16-2020, 08:06 PM   #30
FC7039's Avatar
Allen , Texas
Why is there a metal tab in the opening of the blower air flow.
Old 01-16-2020, 08:24 PM   #31
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
Looks different than my Mach 8 Plus. Just a wild guess that it could be a mount for an optional heat strip? Doesn't look like the heat strip mount on my Mach 8 Plus, but you should have seen the wonky way it was supposed to attach, so anything is possible.
rowiebowie is offline   Reply With Quote
Old 01-20-2020, 11:38 AM   #32
FC7039's Avatar
Allen , Texas
It looks much taller but is only 3” taller than the low profile Penguin. I think because it is much shorter it give the appearance of being much taller. It is supposed to be much quieter. And for the price I can live with it.
ID:	359507Click image for larger version
Old 01-20-2020, 03:11 PM   #33
FC7039's Avatar
Allen , Texas
Who wants it and how are going to get it?
8 yr old Penguin II 15K. When hot out the compressor appears to overdraw current and shut down. If in the low 90s it works. Had Easy Start but I removed it so some wiring will need to be redone. AC and inside ADB.
Need new hitch for new old ride 63air Hitches, Couplers & Balls 3 05-21-2015 08:28 AM
Do I need new wheels if I'm getting new axles? awetsch General Repair Forum 31 03-17-2014 01:42 PM
