05-19-2021, 05:09 PM
2021 30' Flying Cloud
2020 25' International
minneapolis
Leak from air conditioner
Has anyone seen a leak like this? You can see the drip about to fall from the screw. The AC has been running for the past 8 hrs and just started dripping. I just sucked the drain line clear with a shop vac, not sure if that was the issue. This is the first time the AC has been used.
- Stewart
05-20-2021, 11:17 AM
Airstream Ambassador
Jackson Center
, Ohio
Hi s1000pre,*
We're very sorry to learn about the issue you are having. Please send us a direct message with your contact information, email and the last 6 digits of your VIN so we can learn more and share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customersupport@airstream.com
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
05-20-2021, 11:28 AM
1988 32' Excella
Robbinsville
, New Jersey
Fairly common for the drain line to clog due to dirt, leaves, bugs, ect.... and cause leaks inside similar to that. The leaks can also be caused by cracks in drip tray or cups (whichever you have) even just the drip cups shifting position.
05-20-2021, 12:47 PM
2020 28' Flying Cloud
2017 23' Flying Cloud
Hiawassee
, Georgia
He has a new trailer. It’s far too early for drain lines to get clogged, IMO.
05-20-2021, 03:17 PM
minneapolis
It was parked on a slight hill while the AC was running, hitch was roughly 7” low. It seamed to stop dripping once I moved it.
- Stewart
05-20-2021, 03:19 PM
Hiawassee
, Georgia
That’s good, but I don’t think it should have leaked in any case.
05-20-2021, 03:57 PM
minneapolis
I pulled the cover, nothing is visible from up top. You can’t visually see the drip pan...only the electronics, condenser & pump
- Stewart
05-20-2021, 08:19 PM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
I don’t know how much it is leaking, but it if it drips only occasionally it possibly might just be condensation.
Dan
05-20-2021, 08:35 PM
minneapolis
A drip every 15 seconds or so
- Stewart
05-20-2021, 10:48 PM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
I would think that would be too much of a drip rate to be condensation.
Dan
05-20-2021, 11:16 PM
minneapolis
It was 90% humidity yesterday in Minneapolis. Still, I was thinking the same thing. That’s why I pulled the cover. I’ll send an email to Airstream...see if they have any ideas other than take it to a dealer.
- Stewart
05-21-2021, 09:58 AM
1988 32' Excella
Robbinsville
, New Jersey
Mud Daubers can build a nest in the drain line in a couple days.
I believe the newer trailers like yours would have the drip cups, they may be much more sensitive to being off level (same as being out of adjustment).
