Old 12-06-2024, 01:42 PM   #1
2019 27' Globetrotter
2023 30' Classic
Denver , North Carolina
Interior temperature never below 41 degrees
2023 30 Classic. Our front and rear thermostats never register below 41 degrees even when the outside temperature is in the low 20's. This is when the trailer is in storage connected to 30 amp power in "away" mode. The Alde is off and the only possible heat source in the trailer that I can think of is the router which certainly not keeping the trailer at 41 degrees. Has any one else noticed this.
Dave S
link2dks is offline   Reply With Quote
Old 12-06-2024, 08:10 PM   #2
jeffmc306's Avatar
McHenry , Illinois
Dave, could it be that’s the lower limit on those thermostats? Do you have an indoor thermometer that you could leave inside the trailer to see what the real temp is?
Or, perhaps there’s a chunk of uranium in there keeping your trailer warm!
Hope you find the answer.
-Jeff
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 12-07-2024, 09:39 AM   #3
2023 30' Classic
Jeff I'm sure the temp is going below what the thermostat is showing I was just wondering if any one else had noticed this or if it might be an issue with my trailer. I suspect Airstream cheaped out on the thermostats. If you can remotely control the HVAC wouldn't it be nice to know the actual inside temp???
Dave S
Old 12-07-2024, 11:05 AM   #4
2022 33' Classic
Chesapeake , Virginia
Turn on the Alde, and keep the heat/hot water functions off. See what it says as far as interior temp. We usually just use the Alde, and don't even look at the CZone. I assume you have CZone for HVAC control in your Classic 30?
We also have a small magnetic temp/humidity readout on the Norcold fridge. Yesterday morning when I checked on our Classic in outside storage, it was 30F inside.
BGClassic is offline   Reply With Quote
Old 12-07-2024, 11:29 AM   #5
19’ Bambi Flying Cloud
BikeCamper's Avatar
2017 19' Flying Cloud
Airstream Coach - Other
Husqvarnia , Husqvarnia
Our thermostat doesn’t show the temperature inside the trailer. It only shows the setting of the thermostat. In other words, if the thermostat is set at 55, the number shown on the display is 55 regardless of whether it is warmer or colder inside the trailer.
2017 Bambi 19 Flying Cloud
BikeCamper is online now   Reply With Quote
Old 12-11-2024, 10:11 AM   #6
2021 Interstate 24GT
Mustang , Oklahoma
Dave S
Do you have tank heaters? The heaters in the Interstates are set to keep the tank temperatures at 40 degrees based on what it says in the owners materials. Maybe that is it?
dsc789 is offline   Reply With Quote
Old 12-11-2024, 10:19 AM   #7
2023 33' Classic
Chandler , Arizona
I have the 23 classic 33, and as of late ive noticed that the Alde temp does not match the actual temp inside. I have to turn the Aldi interior temp to 80 degrees to get it to actual 72 on the Czone. Im sure its just a thermostat, or maybe the (2) temp sensors mounted inside the main cabin.
Saullman is offline   Reply With Quote
Old 12-11-2024, 12:25 PM   #8
Native143's Avatar
2013 20' Flying Cloud
2014 16' Sport
2019 23' Flying Cloud
Dunedin , Florida
Doesn't your upper right button display the current temp in the Airstream? Mine all have that.
“I haven’t been everywhere, but it’s on my list”.
Rosalita WBCCI #12814
Florida Unit #027, Southeastern Camping Unit #012, Florida Suncoast #129, Stella's Sisters, Grapes & Grains, Indie Streamers
Save
Native143 is offline   Reply With Quote
Old 12-11-2024, 07:11 PM   #9
CBWELL's Avatar
2010 30' Classic
Warren , Manitoba
Does the manual supplied with the unit give the temperature indication features of the thermostat, including set-up, and temperature parameter's of the unit. If nothing else, a call to the manufacturer's tech line is often the best source of information.
ACI #7394
2012 GMC 2500 HD Duramax Denali
2010 Classic Limited 30' ,1994 Excella 34'
1987 Limited 34', 1976 31' Sovereign, 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 12-11-2024, 08:48 PM   #10
BikeCamper's Avatar
I am going to have to check that. We have a replacement thermostat and it may be different.
Old 12-18-2024, 07:00 PM   #11
BikeCamper's Avatar
I found the thermostat manual today. You are correct. Thanks!
1st Year AS FC had Never-Lube Bearings and Never-Adjust Brakes? cru-in Airstream Lifestyle 2 07-29-2019 09:04 AM
Never say never..... StuartsDad Member Introductions 3 08-27-2018 05:36 PM
- 26 Degrees | Everything is fine nunya001 Winter Living 32 05-03-2009 11:13 PM
Frig at 72 degrees, needs to be level ??? wagnerda Refrigerators 18 01-20-2008 05:00 PM
Sweet 16 (degrees) and all's (mostly) well Antique Pedaler Our Community 1 03-04-2007 09:56 PM
