Inside Temperature - Zone 1 reading external
So - I have read a lot of issues with thermostats reading incorrectly, however I haven't seen any that match my issue... thought I would post to see if anyone has any thoughts.
I have a 2021 25' RTB Flying Cloud. My Dometic Thermostat reads the inside temperature just fine when NOT on a zone. However when you switch to zone 1, the 'inside temperature' reads outside temperature. I have only a single AC unit and so there is no 'zone 2' on my rig. It's not the end of the world, but it's kind of a pain when the rig cools off enough, but it's still hot outside. You have to keep adjusting temperature settings in order to keep the inside at the temp you want...
Example: It is 94 degrees outside, and 78 inside. When NOT on zone 1, the inside temperature reading will be 78, when on zone 1 (needed to run the AC), the inside temperature will read 94...
My question is two part....
1. Can I change the location of this temperature probe so it reads better? If so, any idea where it is?
2. Can I re-program my thermostat to run off the actual inside temperature instead of the 'zone 1' inside temperature?
