Old 07-19-2017, 09:01 AM   #21
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Identifying A/C Size
Thermostat placement on the fridge wall is problematic when the bathroom vent fan is operating. In the summer when that vent fan runs, the air conditioner will get triggered by the heat in the fridge enclosure. Likewise the inverse during heating season when excessive furnace run time occurs. I've yet to caulk the area where the thermostat wire passes though the wall on my Classic. I did do that on my Safari. To this day I don't understand why Airstream never has addressed this anomaly when they use the wall that houses the refrigerator as the thermostat location. It only takes a little squirt of caulk to seal that air leak point.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 07-19-2017, 05:01 PM   #22
Wise Elder
Jammer's Avatar
2010 30' Classic
Typically there is a sticker somewhere inside the unit that is visible from the roof once the shroud is removed. Not sure why yours would be missing. I have a photo somewhere.
Originally Posted by pteck View Post
Wondering if I shouldn't take this chance to maybe upgrading to a new 15k penguin? Though I'm also reading that the new ones use a less efficient refrigerant and are possibly noisier. Hrmmm.
Not much practical difference between 13.5k and 15k. They are expensive and not much fun to replace. I would leave it alone if it works.
Help Identifying Trailer therealtoddster 1960 - 1965 Safari 3 05-15-2007 08:02 PM
Need help in identifying this Airstream JimGolden On The Road... 10 01-01-2007 02:56 AM
Identifying the Caravel Monte Jones 1969-1971 Caravel 7 07-19-2006 11:19 AM
WBCCI numbers .. identifying the owners Happycampers WBCCI Forum 7 11-11-2003 11:13 PM
Need help identifying old Airstream! KY Girl Our Community 3 12-12-2002 07:16 PM
