Old 05-03-2017, 09:43 AM   #1
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Hydro-Flame 8535-IV won't light
I tried to use the furnace one morning while we were out for the last two weeks and it wouldn't light. Symptoms are:
1. Fan runs
2. Gas valve opens, I can hear the click and smell gas in the exhaust.
3. Furnace doesn't light, fan continues to run, gas turns off.
I reset it and tried several times, no difference.
I pulled the igniter wire at the control board and tried again after re-start. There was no apparent spark from the coil to the igniter wire.
My conclusion is that the sail switch is good since the gas valve is turning on. The only thing I can see that would cause spark to fail once the gas valve is open is the control board.
Any other suggestions before I order one?
Al
'65 Caravel Hydro Flame valve control unit teeraniti 1956 - 1965 Caravel 7 01-09-2016 08:59 AM
hydro flame won't flame 123f5 Furnaces, Heaters, Fireplaces & Air Conditioning 2 11-12-2010 09:05 PM
Hydro Flame furnace blower quit working won't start nsteel Furnaces, Heaters, Fireplaces & Air Conditioning 3 01-04-2010 03:27 PM
OK, Atwood Hydro Flame 8012 12K just got expensive ronstory Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-13-2009 10:50 AM
Hydro Flame butchncandy General Motorhome Topics 1 01-12-2009 06:20 AM
