RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-11-2020, 06:37 PM   #1
Eagle & Bear's Avatar
1976 29' Ambassador
Madison , Officially SD but are traveling full time.
How to seal gap between exhaust plate and outer skin.
Pulled old Suburban (NT34SP) furnace. There is a chrome plate on the outside of our AS that the intake and exhaust pass through. When I got the plate off there was some kind of dried "putty" that had been used to seal a small (2mm maybe 3mm) gap between the chrome plate and the outside skin.
Since butyl and plumber putty are an oil based material, I doubt that either were used. Anybody know what kind of material is used to fill the gap?
Eagle & Bear is offline   Reply With Quote
Old 11-11-2020, 07:17 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard 👍
Do the google
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
“Change is the new normal, if nothing changes, nothing is normal, everything changes, everything is normal.”
RLC
Tahawus
Old 11-11-2020, 07:23 PM   #3
2002 19' Bambi
Lafayette , California
When removing and remounting (a couple of times) a similar plate for our Atwood furnace, I have used pipe joint compound to reseal the join with the trailer's outside skin. I first tried it because that looked to be what the factory used (we bought the trailer new). The pipe joint compound is heat resistant, has held up well without being affected by the exhaust heat, does not leak, and allows the plate to removed quite easily.
Tim
Tim A. is offline   Reply With Quote
Old 11-16-2020, 06:45 PM   #4
1976 29' Ambassador
Only thing I found was Plumbers Putty. Seems to be OK. If it bursts into flame I will re post.
Old 12-01-2020, 12:27 AM   #5
1976 29' Ambassador
I used plumber's putty to seal the exhaust plate on the outside. Looks like it will hold up for a few years.
Old 12-07-2020, 02:27 PM   #6
1963 22' Safari
marine , Minnesota
if it never sets up...it never fails...
leedr is offline   Reply With Quote
depth between inner skin and outer. or how much space is there?? carl2591 General Interior Topics 2 04-04-2018 03:11 PM
Venting refrigerator in space between outer and inner skin Jeremy9107 Refrigerators 6 02-24-2018 12:37 AM
Outer skin of unit (roof to outer wall) jaharper Ribs, Skins & Rivets 1 08-01-2011 02:05 PM
Trim to cover gap between wall and floor? adwriter73 Floor Finishes 5 02-20-2011 11:02 PM
Gap between floor and shell tmcdougald Repairing/Replacing Floor &/or Frame 4 07-19-2005 06:44 PM
