Houghton AC replacement leaking 1972 Tradewing
Help us track down the leak please. Install went smooth per manual but then short cycled indicating air leak. Water tested and sure enough we have a leak. Used Silaflex 715.
Pulling off to start over... hoping it's readily visible what we did wrong.
Thanks.
Ann - The Constructor's scribe.
Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover.
