Old 10-21-2016, 07:10 PM   #1
LAWBC's Avatar
2013 27' FB International
2012 23' Flying Cloud
GVA , British Columbia
Helpl-Atwood Furnace 8525 won't ignite
Just recently noticed a problem with the furnace not firing up.
While now she won't fire at all just blower motor runs. I have checked the control board and get 2 flashes with a 5 sec. pause, which tells me that there is "Flame sensor Fault " I have done some reading and there is a possibility that the Sail switch maybe shot, which could be the case because I do not hear the ignition ticking at all .
Question. Do I need to pull the unit out to get at this switch and should I be looking for something else?
Has anyone else had a similar problem ?
Laurence
LAWBC is offline   Reply With Quote
Old 01-12-2017, 01:05 AM   #2
LAWBC's Avatar
Exclamation update on furnace problem solved
Update on my furnace problem see previous post, (had tech guy out today). It turns on to be the Electrode. What it was doing was shorting out through the insulator onto the frame holding it. Ordered a new electrode.
The symptoms are; the fan would run and I would hear the odd spark, but noticeably rarely. You should hear the electrode chattering, for about 15 seconds or until in fires up,hopefully. if not then you one of 18 different things that can go wrong.
See attached PDF.
Laurence
Atwood Tankless Water Heater - Will Only Ignite When I Turn On the Bathroom Sink sonyamontana Water Heaters, Filters & Pumps 7 07-11-2016 08:36 PM
Atwood 8525 Furnance Igniter replacement Pappy General Repair Forum 0 07-16-2013 10:06 AM
Gas water heater won't ignite BOWHUNTER74 LP Gas, Piping, Tanks & Regulators 13 04-20-2010 01:13 PM
Both Furnace and Water heater won't ignite? sound-silver Electrical - Systems, Generators, Batteries & Solar 19 11-17-2009 08:30 AM
PLS HELP!!-73 Pilot light won't ignite gas refrig Elf1 Refrigerators 13 06-24-2009 01:22 AM
