Old 08-06-2017, 07:35 AM   #1
philipsinewe's Avatar
2003 30' Classic
Centerville , Ohio
Heat Pump or Not?
Looking at replacing our A/C unit. Currently, have the low profile AC/HP. I have been told by a couple people that the HP switch over system is the most vulnerable part of the unit and is nearly impossible to repair.
Anyone have an opinion on that? I could easily go without the HP side f the unit anyway.
Phil and Kathy Sinewe
2003 30' Classic W/Hensley Arrow
2014 F-150
Centerville, OH
philipsinewe is offline   Reply With Quote
Old 08-06-2017, 07:48 AM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Heat Pump or Not?
Well it's mechanical and like anything it's another part to repair. My experience is 14 years with a heat pump unit. No repairs to date. It does save a lot of propane without a doubt. The up charge I paid when I ordered this unit has been more than covered by the savings of the cost of propane. Keep in mind that it's just not the cost of the reversing valve. A heat pump is most likely going to have more wear on all the components due to increased run time. On the other hand your furnace will probably have an increased life span.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 08-06-2017, 06:06 PM   #3
1979 23' Safari
Wayland , New York
Since you need 120vac to run the heat pump but want to keep things simple a small ceramic heater would probably work as a heat supplement. Still uses electric you would have been using. Plus it's a lot quieter than the ac fan.
Old 08-06-2017, 06:24 PM   #4
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
In heat pump mode, you still have the cycling (noise) of the AC unit. That bothers some people a lot more than it does others. To me that's a bigger issue than the longevity of either unit. None of this stuff lasts forever.
Old 08-06-2017, 06:31 PM   #5
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
We have a heat pump in our trailer and do use it - it came with the trailer when we bought it - used.
Works ok, but if I had to replace the AC I doubt if I would pay the extra for that feature.
Another expensive thing to give problems! I might consider a heat strip in the AC if it is less $$.
An inexpensive alternative is a small electric heater - I feel that is a better option.
Apart from the cost aspect, heat pumps don't work when the temp is close to freezing.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 08-07-2017, 07:43 AM   #6
Half a Rivet Short
2022 Interstate 24X
Hi
.... and while trying to work in the high 30's low 40's they run continuously all night long. Ear plugs anyone?
Old 08-07-2017, 11:05 AM   #7
Muscle Shoals , Alabama
HP aren't very effective below 45 degrees. I'll run it in the morning with electric heaters to get the temp up where it's bearable and then turn it off. At night we usually throw on more blankets when it's freezing or below and run the furnace at 45 degrees.
mschneid is offline   Reply With Quote
Old 08-07-2017, 12:33 PM   #8
jcanavera's Avatar
Fenton , Missouri
Images: 143
Heat Pump or Not?
I also had a heat strip on my 2001 Safari and can speak to that topic. First the heat strip to me is woefully slow in bringing a cold trailer up to temp. Secondly unless things have changed, the heat strip had no thermostatic control. So that means you are constantly having to turn it off on on to maintain an even temperature in the trailer. That got old really fast.
To me if you can live with the noise of the AC in the summer, the noise during the cooler seasons isn't the end of the world. We've found that when you hit 40 or so, it's time to switch to furnace. That furnace is not a quiet appliance either. For those who may want to use a space heater in lieu of the furnace in frozen climes, remember that the furnace will circulate air in plumbing and tank areas to prevent freezing. Use of space heaters or the heat pump will not do that.
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 08-07-2017, 04:10 PM   #9
2007 22' International CCD
Heat strip, even with its limits, has saved our cheese when some dummy let the propane supply get low one cold night.
Old 08-07-2017, 04:27 PM   #10
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Heat pump is noisy and not effective below something like 40 degrees. We've used it but prefer to use the electric heater we carry in marginal conditions. Colder begs the furnace. But once the furnace brings the temp up, the electric heater can maintain it.
2019 Ford Expedition Platinum
Old 08-07-2017, 05:42 PM   #11
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The noise is awful, and heat should be directed to your feet, not your face. We never used it, instead our whisper-quiet Dyson heater or a ceramic space heater prior to that.
Doug and Cheryl
Old 08-07-2017, 06:23 PM   #12
dznf0g's Avatar
Oswego , Illinois
We use ours all the time in spring and fall. Mine puts out really good heat down to upper 30s.
-Rich-
Heat pump or heat strips? coolwhip40 Furnaces, Heaters, Fireplaces & Air Conditioning 17 05-03-2018 09:27 AM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 02:18 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 04:23 PM
