RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-20-2020, 12:32 PM   #1
KK4YZ's Avatar
2020 28' Flying Cloud
2017 23' Flying Cloud
Hiawassee , Georgia
Heat Pump Condensate Drain?
On my 2020 FC THE A/C drain tube is on the street side near the wheel well. I never gave much thought to it but it seems that when in the heat pump mode condensate would/could form on the outside coils.
Weíre camping in SC right now (Lake Hartwell) with nightly lows of about 50 deg. Iím noticing water drain off the roof on the door side of the trailer when using the heat pump. Is there supposed to be a separate drain tube for the outside coils or am what Iím seeing normal?
KK4YZ is offline   Reply With Quote
Old 10-20-2020, 12:41 PM   #2
2007 22' International CCD
Nope, itís Ďnormalí.
When the A/C unit is running as a heat pump, the external coils (condenser normally) will get cold and get wet if there is enough humidity in the air. Unfortunately that water will end up on the roof...
Old 10-27-2020, 05:46 PM   #3
The Colonel's Avatar
2017 25' Flying Cloud
Florence , Alabama
You may try leveling a little heavy on the left side to have it drain off on the other side from doors.
The Colonel and Southern Belle
The Colonel is offline   Reply With Quote
'16 Flying Cloud 25a heat pump condensate running down outer skin majorairhead Furnaces, Heaters, Fireplaces & Air Conditioning 2 05-08-2017 07:38 PM
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 03:18 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 10:58 PM
Condensate Drain mkeith54 All Argosy Trailers 3 08-18-2003 03:01 PM
'70's condensate drain? john hd Furnaces, Heaters, Fireplaces & Air Conditioning 12 04-16-2003 08:05 PM
