Old 10-06-2021, 03:28 PM   #1
2021 25' Flying Cloud
Tucson , Arizona
Heat pump
Can anyone explain what the “heat pump” thermostat setting does comparing to the “furnace” setting?
Bartek is offline   Reply With Quote
Old 10-06-2021, 03:30 PM   #2
Dennis C's Avatar
2020 23' International
Evergreen , Colorado
High level, the heat pump uses a heat strip in the roof-mounted air conditioner unit to provide heat through the same roof vents as the air conditioning. It requires 120V AC power to work. It only provides heat when the ambient temperature is above 45 degrees or so.
The furnace setting uses your gas furnace. It blows hot air through the lower vents, and in many models it blows hot air on your holding tanks. It uses propane, and it can operate without 120V AC by using 12V DC power to run the fan.
Dennis
Previously owned:
2020 International Serenity 23 FB "Sparkle Plenty"
Dennis C is online now   Reply With Quote
Old 10-06-2021, 03:52 PM   #3
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
IMO the furnace is also quieter
urnmor is offline   Reply With Quote
Old 10-06-2021, 04:32 PM   #4
Mollysdad's Avatar
In modern Airstreams the A/C is also a heat pump. Basically it runs the opposite of cool. It takes heat out of the air and sends it to your vents. If you're plugged in and paying for power, it makes sense to use the heat pump. On furnace, you're using your propane for heat.
The downside of the heat pump is it doesn't work very well below 35 deg. So our smart thermostats have a secret program that at a predetermined temperature, switches from heat pump to furnace.
Heat pump air exits at the ceiling, while furnace heat exits at the floor making for toasty feet in the morning. In either case, I'd run a fan to move air around.
You will notice with the HP that the condensate will run off the roof and not down the drain tubes like with cool. It's all because the unit is running in "reverse".
Heat pump or heat strips? coolwhip40 Furnaces, Heaters, Fireplaces & Air Conditioning 17 05-03-2018 10:27 AM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 08:58 PM
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 03:18 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 10:58 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 05:23 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
